B16B Swap
Old Dec 26, 2007 | 11:48 AM
taeim's Avatar
Default B16B Swap
I want to change out the water pump, timing belt, tensioner and tensioner spring but can't seem to find the parts specific for 99-00 B16B.
Can anyone advise me what to do ? I heard I could use the same parts from 00 USDM ITR or USDM GSR parts. Is this true ?
Thanks
Tae
Old Dec 26, 2007 | 12:13 PM
jasony0630's Avatar
76.26.106.124
why a b16b? are you doing it for bragging rights? or just to pay $2000 more for 20 horses?
cuz if its not for bragging rights id just go witha b16a2
Old Dec 26, 2007 | 12:18 PM
crazyguy's Avatar
Default Re: B16B Swap (taeim)
b16b and b16a has the same block.so i think 00 si civic's water pump and everything should fit
Old Dec 26, 2007 | 12:31 PM
taeim's Avatar
Default Re: (jasony0630)
LOL i have always been a fan of CTR specially after I saw coupe of them when i was in Japan. If I can't get the real one, why not build one similar to it right ?
Plus, $2800 shipped is not a bad deal i dont think
B16a doesn't fit. I'm pretty sure B18C parts will do but wanted to make sure of it
Thanks
Old Dec 26, 2007 | 12:39 PM
thisisntjared's Avatar
Default Re: B16B Swap (crazyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">b16b and b16a has the same block.so i think 00 si civic's water pump and everything should fit</TD></TR></TABLE>...i thought the b16b had the b18c(1/5) block the b16a crank and its own rods to give an amazing rod/stroke ratio... you might want to be careful with misinformation like that...
Old Dec 26, 2007 | 01:17 PM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jasony0630 &raquo;</TD></TR><TR><TD CLASS="quote">why a b16b? are you doing it for bragging rights? or just to pay $2000 more for 20 horses?
cuz if its not for bragging rights id just go witha b16a2</TD></TR></TABLE>
God damn it he isn't asking if you like a B16B, he's asking what parts fit the fuucking engine!!! Nobody cares if you like the B16B or not.
Ummm...hell no they do not. B16B = Integra Type R B18C5/B18C block with a destroked crank and higher domed pistons.
Having said that order the T belt and waterpump for an Integra Type R 97/98 or 00/01, or 94-01 Integra GS-R B18C1 are all the same. I'd go OE Acura/Honda parts.
BTW - OE numbers:
Timing belt - 14400-P72-014 (126RU26)
Water pump - 19200-P72-013
I'd also ask for cam seals x2 and 1 crank seal - also for B18C5/B18C1 ITR/GS-R same numbers.
Old Dec 26, 2007 | 01:50 PM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: B16B Swap (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">
Ummm...hell no they do not. B16B = Integra Type R B18C5/B18C block with a B16A (77.4mm) crank, custom rods (142.30mm) and higher domed pistons.
Old Dec 26, 2007 | 02:02 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: B16B Swap (black_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">
My bad on leaving the rods out of the equation, but hopefully someone would understand that a destroked crank would also require longer rods.
Old Dec 26, 2007 | 02:07 PM
sleepyH22's Avatar
your a damn idiot dude...b16b whoops *** on b16a's stock for stock, we all know that...
And like b18c5_eh2 said, no one asked if u like the b16b or what ur preference is..he needs to know what parts fit it..
jasony0630=
Old Dec 26, 2007 | 02:13 PM
taeim's Avatar
Thanks for your advise. I'm going to palce an order based on 00 GSR.
Tae
Old Dec 26, 2007 | 02:15 PM
jasony0630's Avatar
76.26.106.124
god damn it im just trying to help him out
Old Dec 26, 2007 | 02:16 PM
BryanM.'s Avatar
Resident Gearhead
Leave the man alone, he can have whatever engine he wants. Free country - free will.
On a side note, I was not asked but I think the B16B is a cool motor. Go for it!
Old Dec 26, 2007 | 02:18 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: B16B Swap (jasony0630)
How was your post of any help? He wanted to know about engine parts and you hit him with horsepower figures and pricing?
Old Dec 26, 2007 | 02:21 PM
taeim's Avatar
You said to get just one crank seal. Are you referring to the front or the rear ?
Old Dec 26, 2007 | 05:24 PM
black_EM1's Avatar
Community Builder
No worries, man.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by taeim &raquo;</TD></TR><TR><TD CLASS="quote">You said to get just one crank seal. Are you referring to the front or the rear ? </TD></TR></TABLE>
There's technically only one, the front/exhaust cam seal. The distributor goes on the intake cam.
Old Dec 27, 2007 | 05:29 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Sorry I was in a hurry yesterday.
A more thorough parts list would be:
Timing belt
Water pump
Cam seals (located behind cam gears)
Front crank seal (located behind the crankshaft pulley pressed into the oil pump housing)
Valvecover gasket
4 spark plug tube seals (press into underside of valvecover)
Valvecover grommets/top washers with rubber pieces inside if yours look squished at all
***Note*** when ordering valvecover top washers/grommets ask for Type R if you want crome; GS-R if you want black
Old Dec 27, 2007 | 01:09 PM
taeim's Avatar
Hey, thanks for all your help..I'm going to place them in order right now
Old Jan 26, 2008 | 08:04 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jasony0630 &raquo;</TD></TR><TR><TD CLASS="quote">god damn it im just trying to help him out</TD></TR></TABLE>
yeah try not to be so helpful next time, and if you havent noticed b16b's have come down in price A LOT! i picked mine up for $2500 without an ecu which didnt matter cause i got aem ems... oh wait are you gonna freak out on me cause i have aem ems and i could have just used crome?
Old Jan 27, 2008 | 06:39 AM
BryanM.'s Avatar
Resident Gearhead
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by taeim &raquo;</TD></TR><TR><TD CLASS="quote">Hey, thanks for all your help..I'm going to place them in order right now </TD></TR></TABLE>
Exactly one month later. You've done some deliberating. B16B
vmolla1
Apr 20, 2014 11:27 PM
Lambose5
Oct 7, 2013 08:01 AM
703_Sleeper
Feb 12, 2005 06:04 AM
ekkidb16b
Jul 9, 2004 08:23 PM
