opinion on kyokugen lugnuts
Old Jun 28, 2002 | 10:44 AM
speedillusion's Avatar
New User
Default opinion on kyokugen lugnuts
just as the topic tells. i would like to know who has them, who has had them, and overall experience. thanx
MK
Old Jun 28, 2002 | 10:48 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: opinion on kyokugen lugnuts (midnitekreeper)
KYOKUGEN IS SUCK!!!!
in short, they are not a good idea.
Old Jun 28, 2002 | 10:51 AM
Steve91's Avatar
The socket they come with is a POS. You have to be very careful when you remove and install them or the socket will break. Other than that, there okay.
Old Jun 28, 2002 | 11:12 AM
sackdz's Avatar
Default Re: opinion on kyokugen lugnuts (Steve91)
THey're hella light and they work fine if you're not retarded
Old Jun 28, 2002 | 11:15 AM
Kalokohan's Avatar
New User
Default Re: opinion on kyokugen lugnuts (sackdz)
I got some black ones and they are fine as long as you don't use an air wrench to tighten them.
Old Jun 28, 2002 | 11:17 AM
sackdz's Avatar
Default Re: opinion on kyokugen lugnuts (Guardson3r3)
Like I said if you're not retarded. Don't be a lazy *** and use an air wrench they take no time at all to screw in with the key...
[e]You should torque them down with a torque wrench anyway[/e]
[Modified by sackdz, 3:17 PM 6/28/2002]
Old Jun 28, 2002 | 02:44 PM
-Gambit-'s Avatar
i never had a problem with mine, i like mine, they work fine if you dont act like a gorilla and over torque them
Old Jun 28, 2002 | 04:11 PM
boosted3g's Avatar
Default Re: opinion on kyokugen lugnuts (gambit33)
The skunk ones are only half the weight and they are much stronger.
Old Jun 28, 2002 | 05:45 PM
Daemione's Avatar
Default Re: opinion on kyokugen lugnuts (boosted3g)
No problem with mine. Affordable, lighter than stock.
Old Jun 28, 2002 | 06:15 PM
Pho Real's Avatar
Default Re: opinion on kyokugen lugnuts (dLo GSR)
yeah kyokugen is suck.......ummmm no
Old Jun 28, 2002 | 06:28 PM
smokin rubber's Avatar
Default Re: opinion on kyokugen lugnuts (VTEXTC HB)
I getting sick of mine, the key sticks in the nut. Any other ideas of a strong set for my enkei rp-01 wheels
Old Jun 28, 2002 | 07:06 PM
TDRacing's Avatar
Default Re: opinion on kyokugen lugnuts (smokin rubber)
I am all for kyokugen nuts. They help my car turn better, accelerate better, and brake better. The weight savings have cut my lap times by a full half second. The nuts are my secret weapon!
These nuts are a small price to pay, considering what you'll get in return. Everyone around respects me, and i've got all the girls, thanks to Kyokugen wheel nuts.
Old Jun 29, 2002 | 05:21 AM
meept's Avatar
I've had no trouble with mine, so far. However, I don't use an air impact gun on them, and I put anti-seize compound on the studs before installing them (dissimilar metals can stick badly otherwise).
Old Jun 29, 2002 | 11:29 AM
GSRoadRage's Avatar
I have been useing them for over a year now and on 2 different sents of rims and I have had no problems with them at all. I had a set of gorilla locks before and the key stripped out tiwce. Just don't be lazy and use an air wrench on the kyokugens and you should be fine.
Old Jun 30, 2002 | 12:42 AM
NiiS's Avatar
they work fine, and to piggyback on what's already been said, you only need 80LBS of torque to tighten safely. no use in breaking your back(and not to mention your key) to tighten your nuts. no air and a torque wrench and they'll be great
Old Jun 30, 2002 | 09:18 AM
sutrusu's Avatar
Default Re: opinion on kyokugen lugnuts (sinister)
kyukogens are garbage.
Old Jul 1, 2002 | 11:09 AM
New User
Default Re: opinion on kyokugen lugnuts (GSRoadRage)
thank you for all the replies. now i'm aware. you should never torque down lugs with an air/ impact wrench in the first place. thanx guys.
professorman
Aug 6, 2011 07:53 PM
DBAl
Detailing
20
Jun 16, 2009 05:53 PM
MugenGTR
Jul 23, 2005 06:25 PM
duceduce22
Welding / Fabrication
May 22, 2005 07:38 PM
