need help - Alarm Installition
Old Dec 26, 2007 | 11:22 AM
Liu Kang's Avatar
Default need help - Alarm Installition
I'm trying to install an alarm (clifford avantguard) in a '99 Integra LS but having a hard time with the wiring. Does anyone know much about installing an alarm? Specifically, I'm having a hard time finding the wires for the power door locks. Here's the reference I've been using:
http://causeforalarm.thecarthi....html
Any help would be appreciated.
Also any advice in general about installation would be appreciated.
Old Dec 26, 2007 | 11:29 AM
WinningNinja's Avatar
Default Re: need help - Alarm Installition (Liu Kang)
The Audio / Security / Video forum (https://honda-tech.com/zeroforum/27) has really good information for these types of questions. I would try there too.
Old Dec 26, 2007 | 07:57 PM
94_DC4's Avatar
If you car has ABS the wires are located in the harness that is located behind the ABS module. You will have to remove a 10mm bolt that is holding the module in place to get to the wires. The door lock wires are black w/white trace and black w/red trace. They are a negative trigger. Make sure you test the wires. You can PM me if you need help.
Modified by 94_DC4 at 10:31 AM 12/27/2007
Old Dec 27, 2007 | 06:17 AM
Liu Kang's Avatar
does anyone have a writeup of how to install on this car with picts? I know I found lots of useful information under ****INTEGRA FORUM FAQ**** for other stuff and hopeing that someone did that for the alarm, anyone?
unknown_user1
12
Dec 2, 2012 03:50 PM
Episode
Oct 12, 2010 02:28 PM
nomadinabox
Aug 18, 2004 03:14 PM
DSRxMilogen
Jul 3, 2004 06:59 AM
