When to use Aftermarket timing belt with cams?
Old Dec 26, 2007 | 06:28 AM
motormike40's Avatar
Default When to use Aftermarket timing belt with cams?
When do you have to use an aftermarket timing belt? How durable are the stock ones? Who all is currently running a factory timing belt with cams? Thanks.
Old Dec 26, 2007 | 09:39 AM
Big Teggie's Avatar
Default Re: When to use Aftermarket timing belt with cams? (motormike40)
I have always used OEM belts and never had any problems. I personally don't see the need for an aftermarket belt.
Old Dec 26, 2007 | 09:42 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: When to use Aftermarket timing belt with cams? (Big Teggie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Teggie &raquo;</TD></TR><TR><TD CLASS="quote">I have always used OEM belts and never had any problems. I personally don't see the need for an aftermarket belt.</TD></TR></TABLE>
x2 you don't ever have to use an aftermarket belt, it's just a choice. OEM is all I use.
Old Dec 26, 2007 | 11:55 AM
Cool, I'll give my oem one a chance. Thanks for the imput.
Old Dec 27, 2007 | 03:20 PM
Lubo_25's Avatar
doesnt matter theyre all made in the same factory some are red, some blue, and oem black of course...
just tension it correctly and inspect with every oil change and youre golden
Old Dec 27, 2007 | 06:18 PM
TODAwhore's Avatar
Default Re: When to use Aftermarket timing belt with cams? (Lubo_25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lubo_25 &raquo;</TD></TR><TR><TD CLASS="quote">doesnt matter theyre all made in the same factory some are red, some blue, and oem black of course...
just tension it correctly and inspect with every oil change and youre golden </TD></TR></TABLE>
They are not all alike, but yes just get a oem one and check it ever 1k for wear..mostly around the teeth on the back side.
Also what cams are your running?
Old Dec 28, 2007 | 11:18 AM
I got a custom set made from a local cam shop, the specs are intake 11.70, 293 deg; exhaust 11.88, 295 deg. Thanks for all the imput.
Modified by motormike40 at 12:39 PM 12/28/2007
Old Dec 28, 2007 | 11:23 AM
IT GUY's Avatar
Default Re: (motormike40)
what shop? did they regrind stock cams or start with blanks? just curious.
Old Dec 28, 2007 | 11:37 AM
Its called Reed cams and they started with blanks. They are in Stockbridge.
Old Dec 28, 2007 | 11:43 AM
IT GUY's Avatar
that's cool... My office is about 10mins from stockbridge. Might have to check them out.
I had no idea there was a shop like that around here.
Old Dec 28, 2007 | 11:58 AM
Ha yea man kinda surprising, it's off of Eagles landing across the street from the Kroger complex on the corner of Flippen in that business complex.
Old Dec 28, 2007 | 12:01 PM
IT GUY's Avatar
gotcha
I know exactly where it is now.
Old Dec 28, 2007 | 02:39 PM
EG6B20Vtec's Avatar
OEM
Old Dec 30, 2007 | 02:12 PM
TODAwhore's Avatar
Default Re: When to use Aftermarket timing belt with cams? (EG6B20Vtec)
OEM..will have no problems with small cams like that.
Old Dec 30, 2007 | 03:16 PM
goforbroke's Avatar
MEAT PATTY
Default Re: When to use Aftermarket timing belt with cams? (TODAwhore)
Why or how do the teeth on a timing belt get chewed up from running large aftermarket cams?
Old Dec 31, 2007 | 12:30 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: When to use Aftermarket timing belt with cams? (goforbroke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goforbroke &raquo;</TD></TR><TR><TD CLASS="quote">Why or how do the teeth on a timing belt get chewed up from running large aftermarket cams?</TD></TR></TABLE>
usually from P2V contact.
Old Dec 31, 2007 | 12:36 PM
mar778c's Avatar
Community Builder
Community Influencer
Oem
zoopreme
Nov 18, 2009 10:24 PM
turbolshatch
Nov 28, 2007 03:16 PM
EG-cellent
37
Oct 14, 2003 04:00 PM
Gong Show
Jan 27, 2003 11:35 AM
TrueZen
Dec 17, 2002 03:46 PM
