K24/20 N/A CRX 300HP already - what to do more...
Old Dec 26, 2007 | 01:47 AM
itr_18's Avatar
Default K24/20 N/A CRX 300HP already - what to do more...
Hi guys,
my firend asked me to post here a question about his N/A drag CRX. Currently we are preparing to 2008 season. He wonders, what should he do with his car to make it faster / produce more HP and he needs professional answers (not kid's stupid comments)
His setup:
K20 head, K24 block
Cams Toda spec E, Toda Valvetrain, ITB Toda 50mm, Header DTR/ssr 4-2-1 2.5", Custom exhaust 3', Pistons 88 bore and 13.5CR, Rods Crower, Stock crank 99mm,
RC 550cc, Aeromotive regulator fuel, Hondata K pro, stock tranny with drag spool, MH slicks 24.5/8.5/13.
Car has 300 HP, 300 Nm, made 11.4 sec on concrete (no vht trackbite) regular CRX body with lightweight fiberglass parts.
QUESTION: What to do more to make better times/more power etc
Sleeves and bigger bore?
Is dry sump like this a good idea? http://www.adr-engineering.co....dc88f
What else?
THANKS IN ADVANCE.
enigne bay
Modified by itr_18 at 11:02 AM 12/26/2007
Old Dec 26, 2007 | 04:50 AM
DaveF's Avatar
Default Re: K24/20 N/A CRX 300HP already - what to do more... (itr_18)
my suggestion is to leave it alone and work with what you have, tooo many people like to change things and dont even max or get close to maxing out what they have. there are always small changes that can be made to a setup or even a driving style that will help you in the end. i say get out the fine tooth comb.
Old Dec 26, 2007 | 05:46 AM
itr_18's Avatar
But he wants to make better ET's, he knows the car - 11.4 on concrete airport (no trackbite,no dragstrip) is really good time. But ne mods are necessery to go 10's
Old Dec 26, 2007 | 06:10 AM
boostfeen's Avatar
Default Re: (itr_18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr_18 &raquo;</TD></TR><TR><TD CLASS="quote">But he wants to make better ET's, he knows the car - 11.4 on concrete airport (no trackbite,no dragstrip) is really good time. But ne mods are necessery to go 10's</TD></TR></TABLE>
...is he running the 5 or six speed tranny?
...he prob. would make some more power if he does a race port and polish on the head and run bigger valves.
Running the car on race gas will help.
..and maybe ditching the ITB's for ported IM with head light scoop. and use a large TB will help in top end power. ...and of course a good tuner/driver/track bite won't hurt.
Old Dec 26, 2007 | 07:09 AM
itr_18's Avatar
Default Re: (boostfeen)
This season we will use sport gasoline
Head has been polished but bigger valves may couse problems beacuse of "agresive" valves.
Old Dec 26, 2007 | 08:02 AM
2fastGSR's Avatar
King of the One Liners
That setup is more than capable of running 10s as it sits.
There are quite a few 300hp K setups running 10s in probably heavier cars as well.
Not sure if you have a regular track over there, but if traction was a problem on the concrete and you will be continuing to race on that- then what makes you think more HP is the answer?
Old Dec 26, 2007 | 08:38 AM
itr_18's Avatar
Default Re: (2fastGSR)
we want to produce more beacuse we are planning to go to dragstrip which is not that far from us - in Sweden. Im pretty sure that car with this setup will make 10.8-10.9 on dragstrip right now but the score is 10.5 or better.
Old Dec 26, 2007 | 08:52 AM
itr_18's Avatar
How about some "theories and myths" - does dry sump kit like 3 stage peterson or electric water pump help anything if we talk about HP?
Old Dec 26, 2007 | 09:08 AM
efi2nr's Avatar
From: Home of the fastest Hondas in the 417 area since, 1997, usa
your not making 300hp to the wheels with 50mm itbs, I would go to 54mm itbs. Maybe 305hp to the flywheel. Whats your MPH?
Modified by efi2nr at 11:11 AM 12/26/2007
Old Dec 26, 2007 | 09:15 AM
itr_18's Avatar
sure its not WHP its crank HP 305 exacly
Old Dec 26, 2007 | 09:45 AM
IT'S ME DAVID's Avatar
NooB
Default Re: K24/20 N/A CRX 300HP already - what to do more... (DaveF)
sleeves,bigger bore and bigger itb's like 54mm
Old Dec 26, 2007 | 09:47 AM
six sigma racing's Avatar
i would take dave F's advice don't worry about making more power but maximizing efficiency of what you have... I would focus on better tire combo, gearing, and suspension setups to get the car to hook better Anymore power in that CRX and it's worthless without traction
Old Dec 26, 2007 | 10:16 AM
jeffy's Avatar
Default Re: (six sigma racing)
^^^second that. are there stroker cranks yet to go larger than 99mm? if not then bigger bore, methanol, and 15.1cr i would still go to that track and try to get her dialed in with good traction, you might be surprised and pull faster times than you think.
Old Dec 26, 2007 | 10:56 AM
itr_18's Avatar
Thanks for help - so last question - what ET's makes aprox 300-310 HP K24/20's in "stock body" on drag strips in US?
Old Dec 26, 2007 | 03:25 PM
SpeedSceneScott's Avatar
Sounds like you have very limited track time so far. Get to a real track and start making passes. Write everything down, and create a history that you can look back on. You need to make some passes and get a base so you know what you need. You need to get a MPH on the quarter
(or 1/8th, whatever) plus see what it does on a race prepped track.
Old Dec 26, 2007 | 06:10 PM
itr_18's Avatar
you dont need to tell me about it Im racing since 03. My friend just wanted to know what to do more in NA and aksed me to talk about here.
Still no answer about pumps and times I asked
Old Dec 26, 2007 | 07:39 PM
go-pwr's Avatar
The dry sump is always a good idea, it makes more power and oil pressure is constant. If you have the budget then go for it. Also the 54mm ITB or the new Kinslers are a good setup.
bauergold
Oct 10, 2008 01:11 PM
B18 CYA
Mar 14, 2006 11:42 AM
REX VT
Mar 25, 2004 08:48 AM
1stealthls
Mar 30, 2003 04:31 PM
slowcivic
Oct 9, 2001 09:28 AM
