VSS and VTEC engagement
Old Dec 25, 2007 | 08:42 PM
gursh d's Avatar
Default VSS and VTEC engagement
I'm almost finished with a B18C (JDM) swap in my 2nd gen CRX SI. I have heard that VTEC won't engage if the VSS is not working. I have converted to OBD1 via the Rywire subharness with a P72 ECU.
The B18C came with the electronic VSS and my cluster is cable operated. I was thinking about swapping a GSR cluster, but I decided to keep the stock cluster. I am going to take out the electronic VSS from the B18C and put the mechanical VSS from my d16a6. If everything ends up working, will VTEC work? Also, are there any precautions I should take when swapping VSS's or is it simply remove and replace?
TIA
Old Dec 26, 2007 | 03:05 PM
ekb16's Avatar
your cable type vss should work on the gsr tranny without any problems...and yes vtec wont engage if the mhp is reading 0
Old Dec 26, 2007 | 03:08 PM
EKstacy's Avatar
Default Re: (ekb16)
Im not sure if it will all work, but i can tell you that there are noprecautions changing it out. I changed mine on my B16 a few weeks ago and it took all of 10 minutes. heres nothing to it. Good luck
JDM_b20
Nov 17, 2010 03:58 AM
gursh d
Feb 18, 2008 03:46 PM
civic889802
Jan 25, 2006 10:43 AM
7mgtemk3
Feb 21, 2005 05:09 PM
HT Chaplain
May 3, 2003 08:23 PM
