I Need some pointers. Please
Old Dec 25, 2007 | 08:17 PM
mortificationrock's Avatar
Default I Need some pointers. Please
Ok here is my prob im currently installing some Skunk2 Sport Shocks w/Skunk2 Coilovers.But the thing is i really dont know **** about coilovers or droping ones car.How do you measure your drop?Is it the higher the coil goes the lower the drop or viceversa?Sorry about the noobness but i really dont know **** when it comes to suspension.If anyone can share some input i would greatly appreciate it Thanx.Oh yeah one more thing the rubber things i only used one of the ones that came on the package.As in i kept the top one Oem and the bottom rubber Skunk2.Would this be a problem?
Old Dec 25, 2007 | 08:23 PM
forcefedferio's Avatar
Default Re: I Need some pointers. Please (mortificationrock)
No, it is the lower the spring perch is on the sleeve, the lower the car will be. The best thing to do is start with a nearly stock ride height, let the car down to get an idea of how much lower you want it, jack it back up and spin the perches down until you get your approximate desired drop.
As for the bumpstops...ONLY use the one skunk2 provided you, or cut the OEM one in half.
Old Dec 25, 2007 | 08:25 PM
Default Re: I Need some pointers. Please (forcefedferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by forcefedferio &raquo;</TD></TR><TR><TD CLASS="quote">No, it is the lower the spring perch is on the sleeve, the lower the car will be. The best thing to do is start with a nearly stock ride height, let the car down to get an idea of how much lower you want it, jack it back up and spin the perches down until you get your approximate desired drop.
As for the bumpstops...ONLY use the one skunk2 provided you, or cut the OEM one in half.</TD></TR></TABLE>Well i got it wrong its not the bumstops its th rubber mounts that come on the top hat.
Old Dec 25, 2007 | 08:45 PM
TTT
alexpr
Sep 30, 2008 08:05 AM
v!taminb16
Suspension & Brakes
Mar 22, 2008 05:35 AM
blue92da
Suspension & Brakes
Apr 22, 2007 07:57 PM
Lewie
Feb 12, 2003 06:47 PM
civic_tko
Nov 13, 2002 12:52 PM
