diff. crank and rods
Old Dec 25, 2007 | 08:08 PM
egb18c5's Avatar
Default diff. crank and rods
i'm getting a different crank because i had a spun bearing on mine. can i put on my rods without worrying about which place on the crank it goes. the reason for this is because my rods are not being reconditioned. btw this is for a b16
Old Dec 25, 2007 | 08:22 PM
98vtec's Avatar
moderator emeritus
Default Re: diff. crank and rods (egb18c5)
check the bearing clearance...
Old Dec 25, 2007 | 08:40 PM
manoy's Avatar
check first the clearance ,using plastic gauge ,(FOR THE BEARINGS)
Old Dec 26, 2007 | 08:16 AM
egb18c5's Avatar
Default Re: diff. crank and rods (manoy)
the clearance is definitely going to be checked. i was asking because, i was taught that if u rebuild an motor, the rods haves to go on the same place that it was taken off the crankshaft. And, if you recondition the rods, it doesn't matter. any inputs??
Old Dec 26, 2007 | 08:32 AM
racebucket_eg's Avatar
what do you mean by "recondition the rods"?
orioncivic
Aug 15, 2012 04:36 PM
r1de4life
Mar 26, 2008 02:57 PM
sixtodc2
Dec 17, 2007 11:36 PM
