some dc2 questions
will an oem gsr header fit an LS integra?
also will b18a1 cams and gears fit a b1?
and will oem civic struts fit on an integra, or will they not ride right?
1st, the oem exhaust is a manifold, and i think it will fit, but the cat is a different size
2nd, yes the cams and cam gears from a b18a1 will fit a b18b1,
3rd, not too sure, might want to search this a little bit. https://honda-tech.com/zerosearch
its not headers, its only one, and https://honda-tech.com/zero...age=2 there's a couple thread in there that says the b pipe is a different size, and what plastic do you have to cut? <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shawnxme »</TD></TR><TR><TD CLASS="quote">no the headers are different.</TD></TR></TABLE> he didn't ask if they were the same
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CB »</TD></TR><TR><TD CLASS="quote">I would imagin the struts will fit long as the civic is a 92-00.</TD></TR></TABLE>
i know they will fit, but i dont know if it will expletive witch mah ride ya kno
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i_am_a_black_man »</TD></TR><TR><TD CLASS="quote">expletive witch mah ride ya kno</TD></TR></TABLE> dude, english is a good thing in here. and yes they will fit, and they will work, like cb said, as long as they are from 92-00, you shouldn't have a problem. btw, why don't you just break down and buy kyb's for your ride, 150 for a set of 4, or something like that, if you are so worried.
vtack
Aug 15, 2007 08:27 PM
