gas mpg sux
What can i do to get some more out of a full tank of gas, it seems that i used to get 150 a half, now only about a 100-120 miles a half...it also seems to be running rich, or so ive been told
do the basics. using cruise control helps a lot. the more you go gas, slow, gas, slow the more fuel you use. make sure everything is clean, air filters and stuff like that. and you might want to look into getting a fuel injection cleaner. i know there's a company called Mega Power that has a good product for that. look into it with shops around you. it's pretty cheap, and worth it.
Thanks...Ill look into that i dont think that it is a cruise problem even though i only drive about 5 mile each way to work and whatever rec driving to the stores and back, put will keep in mind
