Need paint in a spray can
Old Dec 25, 2007 | 05:48 PM
Jdmglenn's Avatar
Default Need paint in a spray can
I have a 00 si lip that i would like to paint 2000 civic tafetta white. Anyone know where i could find/order some?
all the baxters/ shucks around here only have duplicolor Frost White.
thanks in advance
Old Dec 25, 2007 | 06:18 PM
toyomatt84's Avatar
Sanji
http://www.paintscratch.com
Old Dec 26, 2007 | 03:50 PM
chawski's Avatar
if paintscratch doesnt have it, check out http://www.automotivetouchup.com/
Old Dec 28, 2007 | 12:02 PM
bwolfgti's Avatar
Not sure if you have a Keystone Automotive in your area, but here they will custom mix the paint according to your paint code and then put it in a spray can. Works fine for jambing doors or whatever. Would probably work for your lip if you are not real picky.
Old Dec 28, 2007 | 07:00 PM
integrapunk67's Avatar
If you're in vancouver you should check out the sherwin Williams in Portland... They should be able to do it in spray cans... though there could be a can minimum order.
Old Jan 1, 2008 | 01:51 AM
iam7head's Avatar
Default Re: (integrapunk67)
duplicolor makes a t-white 6oz spray bomb, i got it before in kragen
much cheaper than paintscratch.com
moxi
Oct 21, 2011 03:26 PM
DC5StylZ
Aug 3, 2006 07:10 PM
Y2A
Mar 26, 2003 07:27 AM
roydogg
Feb 12, 2003 09:29 AM
Briman2021
May 4, 2002 04:44 PM
