will a 94 gsr throttle body fit a b16a?
title says it all. i need the throttle position sensor and the map sensor and i have a guy that will sell me a throttle body off a 94 gsr. so will it bolt right up to mine?
OR
is it possible to replace the throttle position sensor on the b16a throttle body even though its riveted in? and if so please explain
thanks in advance
OR
thanks in advance
the answer is yes.... except the throttle cable connector on the throttle body itself is backwards so it wont work, but it does FIT and you can use the sensors or the fast idle air control valve if you need it
