JDM ITR VS USDM GSR Calipers.
I'm not sure if this is the right section for this but i was wondering if the JDM ITR 4x114.3 front and rear calipers are the same as the USDM GSR front and rear calipers. I ask this because I am switching back to 4x100 and if I don't have to change the calipers I wont.
TIA
TIA
I've no idea which calipers the JDM 4-lug ITR uses, but all '94-01 USDM Integra RS/LS/SE/GS/GSR (basically all trims except ITR) use the Nissin 17CL14VN front calipers and 7CLP13S rear calipers.
5-lug ITRs used 17CL15VN fronts and 9CLP14S rears.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MYDA9 »</TD></TR><TR><TD CLASS="quote">bump. Anyone else?</TD></TR></TABLE>
What calipers are currently on your car? Did you check?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
What calipers are currently on your car? Did you check?</TD></TR></TABLE>
Just went out to the garage to check.
Current brakes:
4x114.3 ITR 1996 spec.
Front 17CL14VN
Rear 7CLP13S
My GSR 4x100 calipers:
Front 17CL14VN
Rear 7CLP13S
Looks like I won't have to switch out my calipers so it should be a painless swap back to 4x100.
Thanks Targa250R.
Current brakes:
Front 17CL14VN
Rear 7CLP13S
Front 17CL14VN
Rear 7CLP13S
Thanks Targa250R.
ITR 1996 Spec 4x114.3 front caliper brackets ARE different than USDM 4x100 94-01 RS/LS/GS/GSR brackets. Brackets must be used with the original knuckles.
finished everything up yesterday. On the fronts like I said before, the brackets are different, but the caliper itself is the same. On the rear its the same as the fronts, calipers are same but the brackets are different. The bolts that bolt on the bracket are longer on the ITR model, and the bolts on the gsr model are shorter. That is it, everything works fine, did the rear swap in about an hour.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JLCivixHBDX »</TD></TR><TR><TD CLASS="quote">Not the same</TD></TR></TABLE>
Because you posted parts from a 5-lug ITR, not a 4-lug. The DC2-R caliper pictured is clearly marked "17CL15VN," which is for 11.1" rotors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lewd Nate »</TD></TR><TR><TD CLASS="quote">The jdm type r calipers are the same as prelude calipers in the front. Not sure, but I think the rears are the same as GSRs.</TD></TR></TABLE>
"JDM ITR," "Prelude," and "GSR" are not specific at all
Include specific years and trim levels, and you might have a valid statement there.
What are you talking about? JDM ITR, Prelude, GSR are very specific. He's obviously talking about the 3rd gen intergra. The Prelude calipers are from the same era, the 4th gen Vtec. There's no reason to break down "trim levels". Don't be a jag off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lewd Nate »</TD></TR><TR><TD CLASS="quote">What are you talking about? JDM ITR, Prelude, GSR are very specific. He's obviously talking about the 3rd gen intergra. The Prelude calipers are from the same era, the 4th gen Vtec. There's no reason to break down "trim levels". Don't be a jag off.</TD></TR></TABLE>
93-00 JDM integras and divided into 2 generations?
My understanding is that by saying JDM ITR you could mean either the 96spec or the 98+ spec. My 96spec "JDM ITR" calipers ARE different from 98spec "JDM ITR" calipers because the 98+ are bigger.
It sounds like your calipers are the same as GSRs since you read the part number. But here's a link to a nice big discussion on 96 itr brakes, should answer way more than you really want to know.
https://honda-tech.com/zerothread?id=514109
wats going on guys i have a problem i have SPOON rear rotors 4x114/4x100 but my eg6 rear calipers seem to be to small can anyone tell me wat caliper would wrk for the rotors some say 96 spec itr rear calipers which are hard to find cvan i use gsr ?
So here is a question. A related question at that. I have 96 itr calipers. Earlier in this tread myda9 said that prelude caliper are the same as 96 spec itr calipers. Is this true. If so what year preludes. And would a prelude caliper rebuild kit work for it then. I really want to figure out this out so can stop ordering random honda caliper rebuild kits and just get the right ones.
mattyj
mattyj
I was frustrated by this question so I talked to one of the techs that
work at the honda dealership i work at. he said he would start
checking each car that came through to see of the calipers looked
similer and had similar piston sizes to the 96 itr calipers i have.
Sure enough an 06 civic non si came in and he found an
identical caliper from bore size to piston size to even the same cast
number in the back of it, 5410. He also mounted up my caliper to the
passenger side and it was a direct bolt on to the 06 civic. so i went
back in found the part number for the rebuild kits, 01463-S5D-A00 is
what i came up with. I have already rebuilt one side with this kit and
they went together nicely. It went toghether like it was made for it.
here is all of the cars that the rebuild kits are used on (i dont know
if this means they are the same caliper but the rebuild kits are the
same):
CIVIC 2001 2 EX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2001 2 EX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2001 2 EX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2001 2 EX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2002 2 EX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2002 2 EX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2002 2 EX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2002 2 EX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2003 2 EX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2003 2 EX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2003 2 EX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2003 2 EX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 2 EX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 2 EX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 2 EX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 2 EX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 2 LX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 2 LX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 2 LX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 2 LX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 EX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 EX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 EX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 EX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 EX (SPEC.ED/SIDESRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 EX (SPEC.ED/SIDESRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 EX (SPECIAL EDITION) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 EX (SPECIAL EDITION) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 LX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 LX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 LX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 LX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 LX (SPECIAL EDITION) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 2 LX (SPECIAL EDITION) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2006 2 DX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 2 DX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 2 EX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 2 EX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 2 EX (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 2 EX (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 2 LX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 2 LX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 2 DX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 2 DX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 2 EX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 2 EX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 2 EX (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 2 EX (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 2 LX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 2 LX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 2 DX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 2 DX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 2 EX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 2 EX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 2 EX (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 2 EX (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 2 EX-L 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 2 EX-L 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 2 EX-L (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 2 EX-L (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 2 LX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 2 LX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 2 DX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 2 DX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 2 EX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 2 EX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 2 EX (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 2 EX (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 2 EX-L 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 2 EX-L 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 2 EX-L (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 2 EX-L (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 2 LX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 2 LX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 2 DX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 2 DX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 2 EX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 2 EX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 2 EX (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 2 EX (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 2 EX-L 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 2 EX-L 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 2 EX-L (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 2 EX-L (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 2 LX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 2 LX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 2 DX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 2 DX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 2 EX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 2 EX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 2 EX (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 2 EX-L 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 2 EX-L (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 2 LX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 2 LX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2002 3 SI 5MT CHASSIS ... FRONT BRAKE ('02-'03) ... 001
CIVIC 2002 3 SI (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ('02-'03) ... 001
CIVIC 2003 3 SI 5MT CHASSIS ... FRONT BRAKE ('02-'03) ... 001
CIVIC 2003 3 SI (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ('02-'03) ... 001
CIVIC 2001 4 EX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2001 4 EX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2001 4 EX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2001 4 EX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2001 4 GX CVT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2001 4 GX (SIDE SRS) CVT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2002 4 EX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2002 4 EX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2002 4 EX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2002 4 EX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2002 4 GX CVT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2002 4 GX (SIDE SRS) CVT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2003 4 EX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2003 4 EX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2003 4 EX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2003 4 EX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2003 4 GX CVT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2003 4 GX (SIDE SRS) CVT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 4 EX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 4 EX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 4 EX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 4 EX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 4 GX CVT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 4 GX (ABS SIDE SRS) CVT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 4 LX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 4 LX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 4 LX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 4 LX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2004 4 LX-CAR (CAR SHARE) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 EX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 EX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 EX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 EX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 EX (SPECIAL EDITION) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 EX (SPECIAL EDITION) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 GX CVT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 GX (ABS) CVT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 GX (ABS/SIDE SRS) CVT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 GX (SIDE SRS) CVT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 LX 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 LX 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 LX (SIDE SRS) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 LX (SIDE SRS) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 LX (SPECIAL EDITION) 5MT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 LX (SPECIAL EDITION) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2005 4 LX-CAR (CAR SHARE) 4AT CHASSIS ... FRONT BRAKE ... 001
CIVIC 2006 4 DX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 4 DX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 4 DX (AC) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 4 DX (AC) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 4 EX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 4 EX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 4 EX (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 4 EX (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 4 LX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2006 4 LX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 4 DX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 4 DX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 4 DX (AC) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 4 DX (AC) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 4 EX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 4 EX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 4 EX (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 4 EX (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 4 LX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2007 4 LX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 DX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 DX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 DX (AC) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 DX (AC) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 EX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 EX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 EX (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 EX (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 EX (TRANS-#MPCA-2**) 5AT CHASSIS ... FRONT BRAKE
(1.8L) ... 001
CIVIC 2008 4 EX-L 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 EX-L 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 EX-L (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 EX-L (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 LX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 LX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2008 4 LX (TRANS-#SPCA-3**) 5AT CHASSIS ... FRONT BRAKE
(1.8L) ... 001
CIVIC 2009 4 DX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 DX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 DX (VP) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 DX (VP) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 EX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 EX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 EX (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 EX (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 EX-L 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 EX-L 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 EX-L (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 EX-L (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 LX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 LX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 LX-S 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2009 4 LX-S 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 DX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 DX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 DX (VP) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 DX (VP) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 EX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 EX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 EX (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 EX (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 EX-L 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 EX-L 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 EX-L (NAV) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 EX-L (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 LX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 LX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 LX-S 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2010 4 LX-S 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 4 DX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 4 DX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 4 DX (VP) 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 4 DX (VP) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 4 EX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 4 EX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 4 EX (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 4 EX-L 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 4 EX-L (NAV) 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 4 LX 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 4 LX 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 4 LX-S 5MT CHASSIS ... FRONT BRAKE (1.8L) ... 001
CIVIC 2011 4 LX-S 5AT CHASSIS ... FRONT BRAKE (1.8L) ... 001
same):
(1.8L) ... 001
(1.8L) ... 001
GetawayInMoscow
Feb 9, 2007 03:10 PM
