civic si cluster into another ek????
Old Dec 25, 2007 | 01:40 PM
Midori Green's Avatar
Default civic si cluster into another ek????
ok will a 2000 civic si cluster bolt right up to my ek or not??? and if it does bolt right up will everything work correctly???
Old Dec 25, 2007 | 01:42 PM
z6hatchboy's Avatar
arent those virtually the same chassis, like comparing my eh2 to eg coupe? I would think its plug and play?
ifIexplode's Avatar
Yes, Plug and Play. Tach and everything will work.
Old Dec 25, 2007 | 01:45 PM
Default Re: (ifIexplode)
what about temp gauge???
Old Dec 25, 2007 | 01:47 PM
ifIexplode's Avatar
everything. Take out your old one, Put in SI one, Go drive around.
Old Dec 25, 2007 | 01:51 PM
-JSpecEk*9-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ifIexplode &raquo;</TD></TR><TR><TD CLASS="quote">everything. Take out your old one, Put in SI one, Go drive around. </TD></TR></TABLE>
x2
Old Dec 25, 2007 | 02:01 PM
EM1ly's Avatar
Default Re: (-JSpecEk*9-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ifIexplode &raquo;</TD></TR><TR><TD CLASS="quote">Yes, Plug and Play. Tach and everything will work. </TD></TR></TABLE>
Old Dec 25, 2007 | 02:02 PM
Default Re: (kleeeee)
thanks everybody
Old Dec 25, 2007 | 02:11 PM
adamrg85's Avatar
do you have a motor swap? just asking because never seen any one do it with out a motor swap
Old Dec 25, 2007 | 02:25 PM
Autoworks's Avatar
Default Re: (adamrg85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adamrg85 &raquo;</TD></TR><TR><TD CLASS="quote">do you have a motor swap? just asking because never seen any one do it with out a motor swap</TD></TR></TABLE>
Works the same with or without a swap. I did a few of these swaps back in the day in 96-00 DXs just due to the fact that the Ex and Si clusters looked better and had an OE tach.
Old Dec 25, 2007 | 02:46 PM
Default Re: (Autoworks)
no i do not have a motor swap
Old Dec 25, 2007 | 02:54 PM
3lo's Avatar
3lo
you can even swap the odometer, so your mileage stays the same
Old Dec 25, 2007 | 05:15 PM
Default Re: (3lo)
no my cluster reads 150k and my motor has about 80k
hatch96y7
13
Jan 5, 2007 04:08 PM
needforvtec
Oct 9, 2006 07:57 PM
gribbs
Nov 22, 2005 12:04 PM
rodvang
Nov 13, 2004 10:10 AM
tEK_99
Oct 29, 2001 12:57 PM
