Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
side mirrors?
Old Dec 25, 2007 | 09:48 AM
06siracer's Avatar
Default side mirrors?
i just bought some side view mirrors off of ebay and i was wondring if anybody knows how to take the stock ones off.
this is the place i got them from
http://cgi.ebay.com/ebaymotors/GEN2-06-07-HONDA-CIVIC-2DR-M3-K6-LED-SIDE-MIRRORS-POWER_W0QQcmdZViewItemQQcategoryZ33649QQihZ017QQit emZ270198380907QQrdZ1QQsspagenameZWDVW
Old Dec 25, 2007 | 01:52 PM
FG Deux's Avatar
When you open the door there is little triangular peice on the inside right where the side view mirror connects. That piece should come off exposing the hardware fastening it to the door. My mirror was cliped and that peice was loose, and came off I saw hardware there, it should be exactly where you need to go.
Old Dec 26, 2007 | 07:20 PM
06siracer's Avatar
Default Re: (FG Deux)
sorry i meant
http://cgi.ebay.com/ebaymotors...ZWDVW
Old Dec 26, 2007 | 08:09 PM
mInI m3 Hondeezy's Avatar
Hey i wouldnt trust that auction says gen2 which were the ej,eg's but then it says o6-07 civic seems shady to me.
Old Dec 26, 2007 | 08:42 PM
06siracer's Avatar
Default Re: (mInI m3 Hondeezy)
well i already have them and they don't take refunds so i might as well use them
Old Dec 26, 2007 | 09:12 PM
accordselux's Avatar
Me Gusta History
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mInI m3 Hondeezy &raquo;</TD></TR><TR><TD CLASS="quote">Hey i wouldnt trust that auction says gen2 which were the ej,eg's but then it says o6-07 civic seems shady to me.</TD></TR></TABLE>
Lol, that isn't gen 2 Civics, we're gen 8, then gen 7 01-05, gen 6 96-00, gen 5 92-95
ROFL gen 2 would fit on some thing built in the early 80's.
Gen 2 is the mirror design.
They're the same cheapie mirrors I had on my Accord when I started out making modifications. They're cool for a while, but they are cheap, they can leak, and the power mirror doesn't work as well as you'd like.
Old Dec 26, 2007 | 10:13 PM
06siracer's Avatar
Default Re: (accordselux)
i understand that they are cheap but i didn't see any better ones. a besides gen2 is just part of there name. I've got them here and they came with a bracket(not pictured) that make them fit. I plan on using bondo and a peace of foam behind it to make it not leak. What I need to know is how to take off the side mirrors, so unless U have use full info i would appreciate u not bashing the mirrors i just bought.
Old Dec 27, 2007 | 07:48 AM
Me Gusta History
Default Re: (06siracer)
I just told you, I had the same type of damn mirrors on my car, I'm giving you helpful advice so you don't screw something up. Right now I have loose wires in my door panels because I haven't bothered to hook my mirrors up again after I took the rice ones off and I had to cut them to splice the mirrors together. Then I had to splice the turn signal wiring to get the turn signals to work.
Now I have wires that I wish I never cut because I can't sell the damn car without it looking weird, OK?
If ANYONE can be that brutally honest to you, it's me, because I owned a pair. I'm not in Appearance/Cosmetic just whining about anything that isn't JDM.
With mirrors, there is that triangular piece of plastic that should just pop off the inside (held on by clips), do it gently. Then you should just have the exposed bolts you need.
The big thing, if you want power mirrors, is that you're going to have to splice the wires, and that means cutting them. You might have to take the door panel off to unhook the connector that will help the mirror off.
If you were local i'd help you but i'm just trying to warn you this can end up being more work than it will be worth.
Old Dec 27, 2007 | 07:53 AM
RICO_'s Avatar
NO MERCY!
WTF.......all that work just to put some ebay side mirrors on?
I'll pass.
Old Dec 27, 2007 | 09:39 AM
COMplex.'s Avatar
wow
Old Dec 27, 2007 | 09:58 AM
N3UROM4NC3R's Avatar
Default Re: side mirrors? (06siracer)
If I were going to replace the side mirrors, I would import CTR side mirrors, strip the CW paint, and re-paint with the factory paint to match my car.
Old Dec 27, 2007 | 10:34 AM
06siracer's Avatar
Default Re: side mirrors? (N3UROM4NC3R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N3UROM4NC3R &raquo;</TD></TR><TR><TD CLASS="quote">If I were going to replace the side mirrors, I would import CTR side mirrors, strip the CW paint, and re-paint with the factory paint to match my car. </TD></TR></TABLE>
what are ctr side mirror?
Old Dec 27, 2007 | 10:39 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 06siracer &raquo;</TD></TR><TR><TD CLASS="quote">
CTR = Civic Type R
You could also use the side mirrors from an Acura CSX, which have a turn signals, but they would have to be wired properly to work with an Si.
Modified by N3UROM4NC3R at 11:49 AM 12/27/2007
Old Dec 27, 2007 | 10:40 AM
06siracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordselux &raquo;</TD></TR><TR><TD CLASS="quote">I just told you, I had the same type of damn mirrors on my car, I'm giving you helpful advice so you don't screw something up. Right now I have loose wires in my door panels because I haven't bothered to hook my mirrors up again after I took the rice ones off and I had to cut them to splice the mirrors together. Then I had to splice the turn signal wiring to get the turn signals to work.
If you were local i'd help you but i'm just trying to warn you this can end up being more work than it will be worth.</TD></TR></TABLE>
i know you said u had the same ones on your car and I aprreciate the advice but first thing u do is laugh and make it seem like I just bought some mirrors that didn't go to my car. about the wires there wheresome sellers on ebay that said it was direct plug in, but it was a present so i didn't pick who they where bought thru. I might not install them just because of splicing i would have too do.
Old Dec 27, 2007 | 10:42 AM
06siracer's Avatar
i have a two door, typr r is only four door. I dont think the mirrors are the same.
Old Dec 27, 2007 | 10:43 AM
They're the same cheapie mirrors I had on my Accord when I started out making modifications. They're cool for a while, but they are cheap, they can leak, and the power mirror doesn't work as well as you'd like.</TD></TR></TABLE>
I stand corrected.
Old Dec 27, 2007 | 04:54 PM
Me Gusta History
i know you said u had the same ones on your car and I aprreciate the advice but first thing u do is laugh and make it seem like I just bought some mirrors that didn't go to my car. about the wires there wheresome sellers on ebay that said it was direct plug in, but it was a present so i didn't pick who they where bought thru. I might not install them just because of splicing i would have too do.</TD></TR></TABLE>
I wasn't even referring to you when I wrote that. I even quoted the person I was referring to. So I don't know why you're getting upset about it, I was laughing about the inconsistency.
If you look, and there's a connector at the end that is OEM style, you're in business. Otherwise you have some splicing to do, which will suck.
Old Dec 27, 2007 | 06:00 PM
lostjap89's Avatar
if u do go through with it post some pics
Old Dec 27, 2007 | 07:16 PM
06siracer's Avatar
If you look, and there's a connector at the end that is OEM style, you're in business. Otherwise you have some splicing to do, which will suck.</TD></TR></TABLE>
thanks I will try that out. does anyone know how too take the door off if it comes to that?
Old Dec 28, 2007 | 04:15 AM
racehard81's Avatar
I just received the SLR LED side mirrors.. I have yet to install them but plan to really soon. if i do before anyone posts anything ill let you know
JFK78
Dec 2, 2009 04:27 PM
neophyte2007
Mar 14, 2007 11:39 AM
anht
Aug 26, 2005 05:32 PM
JRizEJ6
Dec 6, 2004 01:18 PM
4doorB18Bcivic
10
Jun 30, 2003 06:14 PM
