timing belt loose!
Old Dec 25, 2007 | 08:26 AM
touandcim's Avatar
Default timing belt loose!
hey. don't post too often but my timing belt is really really loose on my civic si (2k). is the tensioner on it automatic, or can i go i and manually adjust it. i have a shitty chiltons and it says nothing on the topic. it does have aftermarket cam gears on it. i need help fast! thanks in advance
Old Dec 25, 2007 | 08:28 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: timing belt loose! (touandcim)
You can tighten up the slack by adjusting the tensioner.
Old Dec 25, 2007 | 11:05 AM
dayne808's Avatar
loosen the tensioner, put pressure on the crank counter clockwise to put slack on the back of the belt( the side facing the firewall) then tighten the tensioner. don't make it too tight though. check the tension,then redline every gear......
Old Dec 25, 2007 | 12:13 PM
b20xx's Avatar
Default Re: (dayne808)
redline every gear haha
oem helm manual http://hondatech.info/downloads/Auto/Manuals
i didn't bookmark the other site damn it sorry
Old Dec 26, 2007 | 10:48 PM
touandcim's Avatar
thanks guys.
this is much more help than i've gotten in the past.
Old Dec 27, 2007 | 06:28 PM
dayne808's Avatar
did it work?...
Old Dec 28, 2007 | 07:38 AM
touandcim's Avatar
Default Re: timing belt loose! (dayne808)
yeah. didn't have time. the car is garaged anyways but i took a look at it and looks like i might have to lift the car and drop the mount on that side to get access to the lower timing belt cover. is there another way around it? anyways, i was thinking of pulling the motor anyways and would much rather do it then.
Old Dec 29, 2007 | 08:28 PM
strategy400's Avatar
My lower timing belt cover has a small black rubber plug in it to access the 14mm tensioner bolt. might be a bitch to get at without removing the engine mount but thats only a block of wood, a jack and 3 bolts.
pkdog167
Nov 10, 2009 10:29 PM
ragnarok0mega
Sep 16, 2009 08:35 PM
rough_draft
Mar 29, 2005 04:52 AM
Project_ED8
Mar 5, 2004 12:32 PM
sivik2nr
Jun 3, 2003 07:43 AM
