ITR springs
Old Jun 28, 2002 | 09:20 AM
Thrillhouse's Avatar
Default ITR springs
How far will they drop my integra?
Old Jun 28, 2002 | 09:24 AM
ee-gsr's Avatar
Default Re: ITR springs (Thrillhouse)
i've heard approx 0.75"
Old Jun 28, 2002 | 09:37 AM
JDMCRVTEC's Avatar
Default Re: ITR springs (ee-gsr)
yeah if your lucky, its not that the type r springs will lower the stance which they should but very very minimal, its that they are just stiffer then the other tegs springs. If your getting them for free they what they hell its a little better then the stocks springs from the other integras, but if your buying them I would just shell out a little more cash and buy some springs like eibach, or whatever. Just my 2 cents.
Old Jun 28, 2002 | 09:42 AM
Default Re: ITR springs (JDMCRVTEC)
cool thanx guys, what kind of springs should i get if i want to drop it about 1.5 inches and also still be a nice ride? Is 1.5 a good drop or should i go more, i plan on putting 17's on it so do you guys think I will have a bad wheel gap?
Old Jun 28, 2002 | 10:16 AM
JDMCRVTEC's Avatar
IMO I would go more just because its me. you will have wheel gap but it won't bad. I would get the 17's first but don't put them on until you have the money for the springs, just because, so you aren't driving a lifted teg. But anyways get the rims first and see what kind of wheel gap you have and just go from there. If your looking for a good ride the ones i have experienced is Eibach which a very smooth ride, for even a cheaper price and also a smooth ride to is some Sprint springs. So IMO i would wait for the rims first and see how big the gap is. Thats what i did, plus you want have the regrets that I want to lower it more but you already spent the money on the springs you have and already installed them. Or even just get coilovers which won't be as smooth. but you can adjust the height whatever you want.
Old Jun 28, 2002 | 10:50 AM
badnan's Avatar
at what amount of drop do you need to get a camber kit?
im thinking of getting neuspeed sports which give about a 1.75" drop and am not sure if i need a camber kit with that sort of drop
Old Jun 28, 2002 | 10:55 AM
JDMCRVTEC's Avatar
Default Re: ITR springs (badnan)
you will see a little negative camber, but for most cars its not that bad, but I have a 91 teg and I lowered it 3.5 and I needed one bad but 1.75 won't be bad at all just rotate the tires regularly. and it should be fine.
Old Jun 28, 2002 | 12:03 PM
PM-Performance's Avatar
30 mm lower than a gsr last time i checked , so you wont see a diff at all . it will just be a bit stiffer spring .
Old Jun 28, 2002 | 12:55 PM
IN VTEC's Avatar
Default Re: ITR springs (itr206)
you mean 20mm lower. 25.4mm per 1 inch.
Old Jun 28, 2002 | 01:07 PM
Tweakmeister's Avatar
go with something like koni yellows and h&r sports.
don't get 17" rims, they'll look nice and ride smooth but they'll slow you down too. Go for 15" or 16" if you really want the look.
[Modified by Tweakmeister, 10:07 PM 6/28/2002]
Old Jun 28, 2002 | 01:17 PM
Default Re: ITR springs (Tweakmeister)
actually im pretty positive its 30mm . lower than a gsr.
Old Jun 30, 2002 | 07:45 PM
IN VTEC's Avatar
30mm lower = 1.18" lower
Is that what you mean to say?
Old Jun 30, 2002 | 09:08 PM
JM Performance's Avatar
Default Re: ITR springs (IN VTEC)
itr suspension
Old Jun 30, 2002 | 10:45 PM
Mr. Softee's Avatar
Default Re: ITR springs (00SilverLS)
i have itr suspension and it looks fantastic.
Old Jul 1, 2002 | 12:50 AM
strils's Avatar
Default Re: ITR springs (94goldjungsr)
id like to see a pic of somones GSR or LS dropped on ITR springs and stock shocks. i thought the difference was only about 1/2 inch or so.
TeGGY_LS
Mar 30, 2004 11:19 AM
LillDragun
Mar 25, 2003 11:35 AM
b18bfreak
Feb 17, 2003 07:25 AM
