OBD-2 CAR WITH OBD-1 HEAD
I have a 98 obd-2 integra and i have a obd-1 b16 head that i want to put on. iv been searching, googleing and everything for weeks but cant find an answer, can i put the ls obd-2 dizzy and the obd-2 injectors on the b16 head to make it work, and is there anything else that is different besides the alternator cuz im keeping the same block.
I know i will need the ls/vtec conversion kit and also an obd 2 vtec computer and wire in the vtec but im just wondering if i can make the dizzy and the injectors work.
THANKS IN ADVANCED
THANKS IN ADVANCED
Ok so your gonna do an LS/vtec, but you are gonna use the stock LS injectors and a obd2 ecu? I would advise you to convert to obd1, use a chipped ecu for tunability and use better injectors, at least b16 or gsr I'd go h22 though... but to answer your question YES you can, you have to cut one leg off the LS dizzy to make it work though or it will hit the vtec solenoid. Good luck
ok thanks. what i was ganna do about the ecu is get the obd-2 to obd-1 jumper harness and hook up a p28 w/ hondata or w/e i choose to go with for tuning if that would work. so in the end the engine and harness would be obd-2 and the computer would be obd-1. i will get bigger injectors soon and also a type r water and oil pump but i just wanted to know if i could keep it obd-2
