Non ABS axles in ABS integra
went to pep boys other day picked up some reman axles....
think they gave me wrong ones non abs....
needed my car the next day so i installed em anyways...
now of course my abs light comes on ....
im only keeping stock axles til may/june then upgrading to some driveshaft shop axles....
is the any long term damage from running non abs axles in a abs car ???
No damage will be done. The light will remain on because the speed sensors don't have the ring to read the wheel speed. Your abs will not work.
That will definitely trigger a code.
As for the op, you can swap the abs ring over from you old axle if you haven't return it as core. They come off with a hammer, chissel and a little bit of patience.
siblue_gzer
Aug 13, 2007 12:17 PM
