Did I spin a bearing? Rod Knock? Video w/ sound
Old Dec 24, 2007 | 04:43 PM
kenzo42's Avatar
Default Did I spin a bearing? Rod Knock? Video w/ sound
http://www.youtube.com/watch?v=eYnZ5RNjLuE
I had this sound about 6 months ago on a stock 94 GSR. I changed the oil and the sound went away for about 4 months. Recently, the sound came back.
Idle is perfect. Runs perfect. No CELs.
I never over-revved. I was, however, a little low on oil. Maybe a quart low.
Does rod knock come and go? Or should the sounds always be present?
Thanks.
Old Dec 24, 2007 | 05:16 PM
b20gsr10.9's Avatar
Default Re: Did I spin a bearing? Rod Knock? Video w/ sound (kenzo42)
mah dude ur oil pump mite needa be replaced from wut i could hear itz sounds like da oils not gettin 2 da head or better yet 2 da motor
Old Dec 25, 2007 | 02:01 AM
kenzo42's Avatar
Anyone other opinions?
Old Dec 25, 2007 | 06:35 AM
awdgsx96's Avatar
Default Re: Did I spin a bearing? Rod Knock? Video w/ sound (b20gsr10.9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20gsr10.9 &raquo;</TD></TR><TR><TD CLASS="quote">mah dude ur oil pump mite needa be replaced from wut i could hear itz sounds like da oils not gettin 2 da head or better yet 2 da motor</TD></TR></TABLE>
English?
How do you know oil isn't getting to the head?
GSR's are known for walking crank bearings, that may be it. You also said the car has been sitting, have you had a valve/lash adjustment?
Old Dec 25, 2007 | 09:15 AM
kenzo42's Avatar
Default Re: Did I spin a bearing? Rod Knock? Video w/ sound (awdgsx96)
Valve adjustment was done after the knocking started. Car ran perfect.
Also, I did an oil change after I heard the the knocking and the sound went away for about 4 months. Now it's back.
Old Dec 25, 2007 | 06:05 PM
awdgsx96's Avatar
A bearing might be starting to go. The oil could be losing viscosity or something, and not filling the gap as it was before? Just a try. If you have the time and tools are easily in hand, as well as another car, rip off the oil pan and see if anything looks irregular.
Have you tried a magnetic drain plug?
Old Dec 26, 2007 | 08:25 AM
kenzo42's Avatar
bump
Old Dec 26, 2007 | 12:41 PM
GTWITIT's Avatar
Default Re: (kenzo42)
Easy way to check a rod knock, start the car and with it running pull one spark plug wire at a time, if the noise goes away and comes back when you reconnect the wire its a rod knock. If it never goes away adjust the valves. Im pretty sure it .6 on the intake and.8 on the exaust
Old Dec 26, 2007 | 12:56 PM
alexisthemovie's Avatar
that sounds exactly like my spun bearing block.
Old Dec 26, 2007 | 01:24 PM
avoid's Avatar
check the dough nut gasket at the cat flange. The gasket on my car was shot and sounded like that. I also thought is was rod knock until I stuck my head behind the motor with the hood up to listen.
Old Dec 26, 2007 | 02:09 PM
listen to my video.
http://www.youtube.com/watch?v=BAreLQB0i6I
with knock, you will have a CEL and your car will be in limp mode. My car was smoking black at idle. Luckily a new block fixed it.
Old Dec 26, 2007 | 02:39 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: (GTWITIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GTWITIT &raquo;</TD></TR><TR><TD CLASS="quote">Easy way to check a rod knock, start the car and with it running pull one spark plug wire at a time, if the noise goes away and comes back when you reconnect the wire its a rod knock. If it never goes away adjust the valves. Im pretty sure it .6 on the intake and.8 on the exaust</TD></TR></TABLE>
best advice ive seen on this page
if it is rod knock, do not run or drive the car as it may be able to be fixed with out too much damage
Old Dec 26, 2007 | 03:05 PM
650teg's Avatar
If you have the old oil filter still around cut it open and look for metal flakes.
Old Dec 26, 2007 | 05:34 PM
kenzo42's Avatar
Default Re: (alexisthemovie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexisthemovie &raquo;</TD></TR><TR><TD CLASS="quote">listen to my video.
with knock, you will have a CEL and your car will be in limp mode. My car was smoking black at idle. Luckily a new block fixed it. </TD></TR></TABLE>
Why does your knocking sound go away after startup?
I get no CELs, no smoking either.
Old Dec 26, 2007 | 06:10 PM
i think that's the knock sensor kicking in and retarding the timing or something. don't quote me on that.
Old Jan 12, 2008 | 11:04 PM
JDMEK9R's Avatar
if you did spin a bearing your engine check light would definitely be on right?
Old Jan 13, 2008 | 05:45 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Did I spin a bearing? Rod Knock? Video w/ sound (JDMEK9R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMEK9R &raquo;</TD></TR><TR><TD CLASS="quote">if you did spin a bearing your engine check light would definitely be on right?</TD></TR></TABLE>
No, it would not come on because of a spun bearing.
Honda3133
37
Sep 1, 2011 02:08 AM
88_hatch_ls
10
May 10, 2011 05:11 PM
GoldCoin
Honda S2000
16
Apr 23, 2011 07:35 PM
sensasian03
Aug 6, 2010 07:46 AM
caymanjdm97dc2
Nov 25, 2006 09:08 PM
