Civic Vx rims with slicks
Old Dec 24, 2007 | 02:22 PM
tapboyzlilj's Avatar
Default Civic Vx rims with slicks
hey everyone was juss wondering if 22-8-13 slicks would fit on 1992-1995 civic vx wheel ... ? ....
Old Dec 24, 2007 | 04:03 PM
1992Si's Avatar
OK I'll bite.
Yes they'll fit.
Now you'll need to ask if it's a good idea.
Old Dec 24, 2007 | 05:11 PM
Default Re: (1992Si)
is it a good idea maybe not because the rim width right
Old Dec 24, 2007 | 05:53 PM
1992Si's Avatar
Your catching on...
Even back in my day, you wanted the rim as wide as the tire. I know that is not always the way it is done.
The idea is to give the tire the ability to use all of it's width.
I seem to remember some of would even go use a wider rim to try and get the tire to flatten out more.
Last season rota's M/T's would lay over and gain about 1.5" of width. They were mounted on the correct size wheel. It's just the design of the tire that allows it to do that.
Old Dec 24, 2007 | 08:32 PM
Quik Chris's Avatar
...and I think VX's are 5.5" wide, maybe 6" tops. Still. I wouldn't. Why spend the money on slicks then skimp on the wheels.
Old Dec 25, 2007 | 05:34 AM
Dr. D-Series's Avatar
5 inches wide.
I ran them on 23x8's. Better than street tires. But still sucked *****. Best was 1.9's
Old Dec 25, 2007 | 05:07 PM
Default Re: Civic Vx rims with slicks (tapboyzlilj)
alrighty thanks guys going to buy drag racing wheels now thanks...
Old Dec 25, 2007 | 06:55 PM
H22JEFFREY's Avatar
Lensos and call it a day..
Old Dec 25, 2007 | 10:53 PM
ExospeedAMcrx's Avatar
each slick has its recommended rim width. You cant always get the EXACT rim width needed for each tire so the best bet is to at least keep it within 1.5" of the recommended rim width for that slick.
The contact is affected if youre not on the proper rim size. 8" wide tire on a 5.5" wide rim, is just too much. thats a good 2.5" and what it will do, depending on the tire pressure you are at is the contact patch on the tire will change. You may only be grabbing on 50% of the center of the tire and you're not getting the best performance out of it.
Best bet, get a good matching rim.
gsr96cx
Nov 19, 2008 10:24 PM
5thgearburnout
Feb 18, 2007 05:54 AM
b16bluef
Mar 4, 2005 05:51 PM
93FastLs
Nov 3, 2004 02:31 PM
HX_Guy
Oct 10, 2001 12:29 PM
