High oil pressure
Old Dec 24, 2007 | 02:03 PM
roachsboosted16's Avatar
Default High oil pressure
ive noticed that after installing my turbo my car has very impressive oil pressure - cold 100+psi, warm 25psi, and high rev 100+psi. is this wayyyy to high, because its starting to cause problems, broken oil coupler, and leaks. its leaking most is at the turbo feed line. should i put a tee there and feed it back to oil pan?
Ok that was the problem. i saved my turbo from blowing a seal, but my oil pressure is still too high.
a idle its 100+psi, high reving wen cold - im too scared to do, high revving when warm and it gets about to 175psi, waayyyy in the red. the turbo feed line is not the problem, (ive bored the tip out and nothing changed). any ideas as to whats rong or should i run it with 175psi oil pressure?
Modified by roachsboosted16 at 5:05 PM 12/24/2007
Modified by roachsboosted16 at 6:01 PM 1/2/2008
Old Dec 24, 2007 | 02:21 PM
Default Re: High oil pressure (roachsboosted16)
bump
Old Dec 24, 2007 | 02:34 PM
MidShipCivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roachsboosted16 &raquo;</TD></TR><TR><TD CLASS="quote">ive noticed that after installing my turbo my car has very impressive oil pressure - cold 100+psi, warm 25psi, and high rev 100+psi. is this wayyyy to high, because its starting to cause problems, broken oil coupler, and leaks. and advice, where its leaking most is at the turbo feed line. should i put a tee there and feed it back to oil pan?
i have searched, no help</TD></TR></TABLE>
Before I say anything smart ***-ish show me a picture of your oil in and out lines on your turbo.
Old Dec 24, 2007 | 03:34 PM
Default Re: High oil pressure (MidShipCivic)
gimme a couple minutes for pics.
Old Dec 24, 2007 | 03:57 PM
ther it is
theres the feed up close
theres the return, hard to see, but its 7/8" to 1" diameter.
Old Dec 24, 2007 | 04:04 PM
should i use a different oil other than 5w such as 0w?
Old Dec 24, 2007 | 04:16 PM
You need braided line on that and is that a restrictor? You better have one before you blow the seals on that turbo charger.
Anywhere else besides the turbo lines it's leaking from?
Old Dec 24, 2007 | 04:20 PM
Default Re: (MidShipCivic)
no i dont have a restrictor on it i cant find one that fits, do u know where to get one? that will screw in? no it only leaks at feed line.
and why does return need to be braided? sorry if dumb questions
Modified by roachsboosted16 at 5:31 PM 12/24/2007
Modified by roachsboosted16 at 5:33 PM 12/24/2007
Old Dec 24, 2007 | 04:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roachsboosted16 &raquo;</TD></TR><TR><TD CLASS="quote">no i dont have a resistor on it i cant find one that fits, do u know where to get one? that will screw in?</TD></TR></TABLE>
Go to a hardware store and try your inlet fitting with a 1/8 npt female fitting see if that works, because I'm not sure what you have on there. Then get one of these if it is.
http://www.atpturbo.com/Mercha...e=OIL
At the turbo or at the block where is it leaking close up of the line please (FEED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
and why does return need to be braided? sorry if dumb questions</TD></TR></TABLE>
Oh so thats the bottom picture.
Old Dec 24, 2007 | 04:38 PM
thank you
Old Jan 2, 2008 | 05:02 PM
bump
Old Jan 2, 2008 | 05:53 PM
Riake's Avatar
so you think you really reach 175 psi?
Also in the first picture, the feed looks to be braided but in the up close picture it is not. Put a braided feed line on there. You dont need one on the return though.
Old Jan 2, 2008 | 06:33 PM
if you are really doing 175 PSI your bearings won't be long lived.
Old Jan 2, 2008 | 06:35 PM
well my gauge goes to 100psi, then about another quarter of the gauge is red, and it maxes the gauge out. so im guessing its around 175...
yes the feed is braided.
Old Jan 2, 2008 | 06:41 PM
Default Re: (roachsboosted16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roachsboosted16 &raquo;</TD></TR><TR><TD CLASS="quote">well my gauge goes to 100psi, then about another quarter of the gauge is red, and it maxes the gauge out. so im guessing its around 175...
yes the feed is braided.</TD></TR></TABLE>
Is that a rebuilt engine? And show me a better picture of the braided line going into the fitting on the turbo .
Old Jan 2, 2008 | 06:42 PM
no it is original engine no rebuild, and yes it is for sure braided.
Old Jan 2, 2008 | 06:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roachsboosted16 &raquo;</TD></TR><TR><TD CLASS="quote">no it is original engine no rebuild, and yes it is for sure braided.</TD></TR></TABLE>
So I don't see a need to come to the conclusion of tight clearances. Can you swap gauges with anyone? To check your gauge out, and is that a barbed fitting on the turbo feed line?
Old Jan 2, 2008 | 08:06 PM
SOHCD16y8's Avatar
Was the gauge reading normal before the install?
Old Jan 2, 2008 | 08:44 PM
cbustuner's Avatar
Default Re: (SOHCD16y8)
is this an electric or mechanical gauge
Old Jan 2, 2008 | 09:04 PM
quicksilver1689's Avatar
i ♥ snails
something founds weird that is very high for oil pressure. where is the gauge sender located?
Old Jan 3, 2008 | 03:37 AM
nasteboyii's Avatar
DOUBLE check the vehicle with a secondary guage/sender to make sure the guage is not the issue
ive had a similar problem with a guage causing me drama when there was nothing wrong other then the guage
after that , start checking for restrictions
dan
Old Jan 8, 2008 | 08:56 PM
JaredKaragen's Avatar
is there a chance your line is leaking?
If you running a wet-floating type turbo and at-least a 36" oil line, it will not need a restrictor; I see 100+PSI cold start with no leaks.
Check your equipment; use some carb cleaner to spray off all the oil around the line when cold, then have a friend start it up so you can see exactly where it's coming from;
for the love of god don't spry it ont he turbo when it's still hot =P
Old Jan 8, 2008 | 09:23 PM
riceburner700's Avatar
Default Re: (JaredKaragen)
i would get an oil restrictor and if you want to lower your oil pressure a little while cooling it get an oil cooler kit
Old Jan 10, 2008 | 01:31 PM
Default Re: (riceburner700)
If he puts a restrictor on that ebay turbo it will probably have shaftplay in notime. I see 100+PSI on my turbo'd D15b all the time, no excessive leaks or oil burning.
Old Jan 11, 2008 | 08:55 AM
187Chor's Avatar
would high oil pressure be a reason why oil might come out of the cold side of the turbo?
