rota slipstream 15x6.5 can i use my stock gsr tires?
Old Dec 24, 2007 | 12:41 PM
Gant's Avatar
Default rota slipstream 15x6.5 can i use my stock gsr tires?
i have gsr blades just looking for a differnt rim for my daily beater, will my stock tires work on slipstreams?
Padawan's Avatar
Darth ModerVader
Default Re: rota slipstream 15x6.5 can i use my stock gsr tires? (Gant)
Yes, they will.
Old Dec 24, 2007 | 02:02 PM
92teginsc's Avatar
Default Re: rota slipstream 15x6.5 can i use my stock gsr tires? (Padawan)
sure
Old Jan 3, 2008 | 09:56 PM
Gant's Avatar
one more question is the gsr a 6.5 width rim?
if i get a slipstream in a 7inch width will it still look ok with my gsr tires?
Old Jan 3, 2008 | 11:30 PM
95TegSE's Avatar
Default Re: (Gant)
GSR is 6" wide. 7" wide is on the upper end of the recommended width for a 195 (stock tread width) tire. I would just go up to a 205.
Old Jan 4, 2008 | 12:44 AM
alexisthemovie's Avatar
what size are you running? If 195/55, they might look normal, but if 195/50 or even shorter, then you'll have a stretched look.
Old Jan 4, 2008 | 03:53 AM
92teginsc's Avatar
Default Re: (alexisthemovie)
205/50's will look good
Old Jan 4, 2008 | 07:37 AM
gofastgokart99's Avatar
They call me the part of a womans vagina that causes pleasure.
Default Re: (92teginsc)
here is my whip with 16x7 slipstreams....tires are 205/50's
Old Jan 4, 2008 | 07:50 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (gofastgokart99)
On an Integra with 15" wheels, you should be using 195/55-15 or 205/50-15. Either size will fit fine on the stock 15x6 wheels as well as on aftermarket 15x6.5 wheels. You can use them on 15x7, but they'll look a bit stretched, unless you've got the Falken Azenis RT-615, whose size is a bit bigger than other 205/50-15 tires; otherwise, I would stick with 15x6 or 15x6.5.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gofastgokart99 &raquo;</TD></TR><TR><TD CLASS="quote">here is my whip with 16x7 slipstreams....tires are 205/50's</TD></TR></TABLE>
205/50-16 is too big for an Integra. On 16" wheels, stick with 205/45-16 or 215/45-16.
Old Jan 7, 2008 | 11:01 PM
Default Re: (nsxtasy)
[/QUOTE]
yeah new tires for spring will be 205-45's
csulliva
Mar 14, 2008 11:57 AM
kaspur_eh
Apr 23, 2004 08:08 PM
gakkuken
Apr 18, 2004 02:28 PM
Ohlias
Jun 23, 2003 09:33 AM
IntEGNYC
Nov 14, 2002 06:49 PM
