Buddy Club Spec 4 cams
Old Dec 24, 2007 | 10:12 AM
eg6madness's Avatar
Default Buddy Club Spec 4 cams
I installed my buddy club valvetrain setup, and their .5mm headgasket yesterday along with Spec 4 cams into my B18Cwhich contains P30 pistons.
Well i did every thing the way it suppose to be, i brought the crank to TDC and the Cams to TDC (using the Buddy Club cam Gears) installed the timing belt and everything else. turned the engine by hand a few times to see if there was any contact.
We started her up and it wouldnt hold idle at all..... I figured i would adjust the mixture at idle since i have the Hondata S300. I tried revving it few times and didnt hear any metalic sounds or any detonation.
I fixed the idle as best as i could but the car still is a little lumpy, but i know i need it tuned. just wanted to get it idle and running.
Anyway i was driving on my way to work and got to around 3000 RPM, and accelerated a little just to bring it into VTEC. when i did and continued pass i heard a slight metallic ringing so i cam off immediately. I heard that sound b4 when i had my D15b vtec and i had the cam timing out.
Do these cams have clearence issues in a B18C Block with P30 pistons????
Dont the Buddy Club Gears line up at TDC when the crank is at TDC ?
I have both gears set at 0.
I think my timing has to be out some what my Distributor isnt as centered as it usually is, it is in a slightly retarded position but with the timing light is it still saying 16.
any suggestions?
Old Dec 24, 2007 | 02:28 PM
eg6madness's Avatar
Default Re: Buddy Club Spec 4 cams (eg6madness)
anyone???
is there usually clearence issues with the P30 pistons in B18C block and Buddy Club Spec 4 cams
Old Dec 24, 2007 | 03:20 PM
snm95ls's Avatar
With a setup like that, you really should have clayed the engine to find out if there are any clearance issues.
Revving the engine a few times on the low cam tells you nothing.
Other than that, I can't really offer any advice.
Old Dec 24, 2007 | 03:29 PM
nogohatch's Avatar
Default Re: Buddy Club Spec 4 cams (snm95ls)
im also intrested in this somewhat, i may be buying a set of these cams for a ls vtec im building, and any knowledge before hand so i dont jump into it clueless without the valuable knowledge
Old Dec 24, 2007 | 04:19 PM
eg6madness's Avatar
I guess i should have clayed.
Does anyone else know if they are usually any issues??
haulinhonda
Mar 11, 2013 02:11 AM
LS/V-T
15
Jan 2, 2011 08:59 PM
matix
Sep 6, 2005 09:10 AM
VTEC Visions
49
Sep 3, 2005 11:19 PM
bananacruzier
Apr 10, 2002 08:39 AM
