please help
hey guys i thought i blew a head gasket on my civic so i replaced the head gasket (the chamber will filled with water)and its still smoking.so i pulled the plugs and they were dry.what else could it be.but ill shut the car off for about 10 20 minutes and then start it again and it wont smoke until i give it gas.what else could it be im stumped?
i had it sent out the said it was fine but if the head was warped or cracked dont you think there would be coolant and water int he chambers again and the plugs would be wet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93baggedcivic »</TD></TR><TR><TD CLASS="quote">i had it sent out the said it was fine but if the head was warped or cracked dont you think there would be coolant and water int he chambers again and the plugs would be wet</TD></TR></TABLE>
It depends on how hot the remaining 3 firing plugs got.
i pulled all 4 plugs and they all looked the same little carboned up thats it so i cleaned them and put them back in and pulled them and they were carboned i know its running rich so.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cln92eg »</TD></TR><TR><TD CLASS="quote">What motor is this and is there anything done to it? Boost Ext.</TD></TR></TABLE>
Good question!
I didn't think about a coolant line leaking into the turbo.
Good question!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Gary- »</TD></TR><TR><TD CLASS="quote">Did you check the head to see if it was warped prior to changing the gasket?</TD></TR></TABLE>
My thoughts as well go to warpage, get it milled at minimum maybe .010 or .020 and see what that does, should only run like $35.
No smart a$$ my GSR is boosted and my cousin broke my oil return line and it caused white smoke to come out so i changed my head gasket well started it back up and still did it cause my oil line. Im just tryin to help him out and any info would help me know more about his car we dont need smart a$$'s if your not going to help him
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cln92eg »</TD></TR><TR><TD CLASS="quote">No smart a$$ my GSR is boosted and my cousin broke my oil return line and it caused white smoke to come out so i changed my head gasket well started it back up and still did it cause my oil line. Im just tryin to help him out and any info would help me know more about his car we dont need smart a$$'s if your not going to help him </TD></TR></TABLE>
Uh...I was being sincere.
Lighten up a bit OK.
Lighten up a bit OK.</TD></TR></TABLE>
Hows that theres no coolant lines running to a turbo so u were trying to be funny which wasnt
It depends how much its warped, if its not too much it may just be enough to vaporize in the combustion chamber while the car is on under pressure, and not enough to really just leak.
It depends on which turbo you use; it's not like there's on turbo in the world and we all have to use it.
I wasn't trying to be funny, as I said I was being sincere and trying to help. You seriously need to lighten the **** up.
</TD></TR></TABLE>It depends on which turbo you use; it's not like there's on turbo in the world and we all have to use it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy »</TD></TR><TR><TD CLASS="quote">
My thoughts as well go to warpage, get it milled at minimum maybe .010 or .020 and see what that does, should only run like $35.</TD></TR></TABLE>
I would try what hes saying and check the head gasket make sure its all clean and hope it does blow white stuff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy »</TD></TR><TR><TD CLASS="quote">Im not being a smart a$$ but if you run a dsm turbo, you may very well have coolant lines running to turbo, b/c they're both coolant + oil lubrcated and cooled.</TD></TR></TABLE>
This is what I'm talking about. I wasn't being a dick, but rather trying to help.
im not trying to say your wrong about the warped head but when i started it before the new h/g it would smoke up the block lol and now its not half as bad it will take like 5 minutes to fill up my garage.
