Classic Hondas All Pre-1988 Hondas.
Battery light stays on
Old Dec 23, 2007 | 10:49 PM
kevinh47's Avatar
Default Battery light stays on
On my 88 Accord LX the battery quit and after charging, the dash battery light stays on even with the key out. The battery was old and didn't hold the charge well so I got a new battery. Well the dash light still stays on and the battery will drain over night.
I've pulled all the fuses and the light stays on.
After starting the engine the dash light dims but is still on. Also the oil light is on after starting and the oil is full and the car runs fine.
Any ideas of what to look at next?
Old Dec 24, 2007 | 04:03 AM
ludesrv's Avatar
You have a drain on your battery. That's why it dies overnight. You must find it for your car to be good again. It won't be easy. Think of all the wiring you have modified and double check it. Check all your grounds and use a multimeter to help you find the drain.
Good luck.
AddictionJDM
Honda Civic (2001 - 2005)
Apr 6, 2016 06:49 AM
Mexan02
Jul 23, 2006 07:36 PM
ceLtic
Jun 11, 2004 06:50 PM
xsellxoutx
Apr 25, 2004 01:14 AM
SouLaQuaRiuS
Apr 15, 2003 06:41 PM
