Hondata S300 Users,.... i need a map
Old Dec 23, 2007 | 08:27 PM
eg6madness's Avatar
Default Hondata S300 Users,.... i need a map
I have a B18C with the Buddy Club Valvetrain, and Spec 4 cams, P30 pistons, lightened flywheel and hondata s300.
I would like to know if anyone has a Basemap for this type of setup or similar that will help me idle properly, and get out a few of the sputtering spots at low rev range.
I need a basemap to just use for the time b4 i get to the dyno...which is booked for mid Jan....
Old Dec 23, 2007 | 08:47 PM
TTR's Avatar
TTR
Default Re: Hondata S300 Users,.... i need a map (eg6madness)
I have something close for 44occ injectors, for a 13.5:1 motor on 93 octane.
Old Dec 23, 2007 | 08:57 PM
eg6madness's Avatar
Default Re: Hondata S300 Users,.... i need a map (TTR)
If you are willing to share. can you email me it ....i am PMing you my email
Old Dec 23, 2007 | 09:10 PM
TTR's Avatar
TTR
E-mail sent.
Old Dec 23, 2007 | 09:21 PM
EatSleepJDM's Avatar
do you mind sharing with me as well?
Old Dec 23, 2007 | 09:25 PM
TTR's Avatar
TTR
Default Re: (EatSleepJDM)
Sure why not.
Old Dec 24, 2007 | 04:12 PM
eg6madness's Avatar
Default Re: (TTR)
Ok i got it to idle a bit but it is idling in Columns 3 and 4. and it is super rich ( i can smell fuel really strong).
how can i combat the richness and idle in colums 1-2 with out the car cutting out?
Old Dec 25, 2007 | 08:10 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (eg6madness)
you could try contacting Church Automotive in So Cal, they sell good basemaps for a reasonable price. There are others as well on this board, just do a search for "basemaps" etc.
Old Dec 25, 2007 | 01:29 PM
TTR's Avatar
TTR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6madness &raquo;</TD></TR><TR><TD CLASS="quote">Ok i got it to idle a bit but it is idling in Columns 3 and 4. and it is super rich ( i can smell fuel really strong). how can i combat the richness and idle in colums 1-2 with out the car cutting out?</TD></TR></TABLE>
Add or subtract 5% at a time until it smooths out, getting the car to idle in the first two columns may not be possible due to the camshafts. Do you have a wideband? What do you mean by cutting out?? Check the TPS voltage with the car running, make sure it is at .5 volts at idle, if it is less than that, the ecu will think the throttle is closed, when it's not. You can check it in the TPS tab in S-Manager, start the car and hit read next to the minimum box. If its a negative value move the TPS until it reads 0 or slightly positive. Better positive than negative.
Old Dec 25, 2007 | 05:21 PM
eg6madness's Avatar
Default Re: (TTR)
Cutting out=dies/ bogged down til it dies
I dont have a wideband anymore, have to order another one next week. however a friend told me that he will help me tune it on friday
i was adjusting the maps today with his help and he told me my INJ reading is too high at idle... it was reading around 8.76 he told me take out some fuel ...I did and the car idles nicer now, every minute or so it jumps up to 1500rpm and come back down to 850-1000. the INJ now reads around 3 and works better.
driving is still pretty rough though
MARVNVRAM
Engine Management and Tuning
Apr 24, 2009 02:46 PM
eg:R
May 29, 2006 01:51 AM
TurboIntegra
Sep 7, 2002 10:41 PM
DUALSTAGE
May 3, 2002 02:41 PM
