Lighting HID/Xenon kits, Retrofits and Associated Topics
my 1st EK retro (tons of pics)
Old Dec 23, 2007 | 08:26 PM
Mefain's Avatar
Default my 1st EK retro (tons of pics)
well ive decided i wanted retro'd headlights...but i couldnt afford the cost of having it done
1st i start off with stock 99/00 Si headlights
then they were baked at 200 for about 10-15minutes then the outcome was this
then i got these hella projectors and d2s bulbs from a member on here (topdog)
i checked out there cutoffs in the garage with no shrouds (they were not made yet)
here it is at about 5ft
and around 7-8ft
and again around 25-30ft
now keep in mind that is only one projector w. no shroud
i called my buddy (colinproctor on here) over to help w. the shrouds being as he has more patience than i do, and after a few hours of work we have them mocked up and ready to be finished
they started as this
and became this
that is pretty much all i have completed on this project, i have mocked up a location i would like to mount onto the reflector, but not sure if it will work
maybe someone can point me in a good direction as to what i could add to the current shroud to finish it off in the housing, i dont want to have the rear of the projector visible, but i cant find anything to finish it off
please any help/suggestions/guidance or anything is appreciated and thank you in advance
Old Dec 24, 2007 | 01:26 PM
doubleshotz's Avatar
Default Re: my 1st EK retro (Mefain)
I'd paint the piping part of shroud and leave the ring polished.
What color is your car?
Looking good so far
Old Dec 24, 2007 | 01:38 PM
Mefain's Avatar
the car is an orange type color...and the headlight is the stock polished, it will not be painted
Old Dec 27, 2007 | 08:41 AM
Genuine Rolla's Avatar
so far so good man..!
Old Dec 27, 2007 | 08:48 AM
Mefain's Avatar
there is the same thread in the a/c section, i posted it there cause i knew it would get more hits, it also has teh updates
https://honda-tech.com/zerothread?id=2182960
Old Dec 27, 2007 | 09:30 AM
Turbo EG4's Avatar
From: Ghost riding my grandmamas whip YEP, Los Angeles Cali
Default Re: (Mefain)
sweet diy!
Old Dec 28, 2007 | 11:54 AM
Imp-tuner's Avatar
From: Santa Ana ES in 415 NORCAL where clean ricers are found :P
Default Re: (Turbo EG4)
Nice u have done it.....for it sucked....I forgot the left headlight for 2 expletiveing xtra minutes and the headlight melted from below...expletiveing ****.......
Old Dec 28, 2007 | 12:28 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
You need to post the updates in this thread.
And for a shroud, it looks like a metal funnel would work well:
Not sure where that image came from.
But yeah, with a shroud like something made from the funnel, your pipe piece around the projector isn't really all that necessary. I'm using the same projectors and I didn't put any covering around the projector. Neither do the cars that come with those projectors as stock. You just need a shroud around the lens to keep the reflected light inside the headlight housing.
Old Dec 28, 2007 | 03:39 PM
Mefain's Avatar
well im tryin to make some custom....i dont want a 2-piece but the way i want it, it will need to be done this way, i have it planned to get it machined 2morrow, i will update if it happens
Old Dec 28, 2007 | 03:49 PM
Mefain's Avatar
im tryin to achieve a shround like the one in the back of this picture
Old Jan 1, 2008 | 06:58 PM
Mefain's Avatar
i updated the other thread again for those that dont see it in the a/c forum
Mefain
Mar 21, 2008 10:48 AM
U N S E E N.
Sep 8, 2005 08:15 AM
1995chardx
Apr 23, 2005 08:45 PM
SyDuck
Jul 4, 2004 12:31 AM
Redek4
Mar 21, 2004 04:44 PM
