3 ECUs for sale
i have 2 ECUs for sale
1 P06 converted to P28 each tested and working
1 P75 converted to P72
i used this ECU just for tuning with Crome. I installed the Knock board for a P72 and i bridged pins inside the ECU to keep from having problems with VTP and the IABs
its done like this, not my ECU
i also installed a jumper at j12 for data logging here is a picture. this isn't the p72 but you get the idea.
all you have to do is pull the jumper to data log and put it back when you are done. i also put a jumper in at j1 in case i ever needed to revert back to the stock LS base map. the p72 lives in a pr4 case. its was the only case i had that could accommodate the knock board.
These guys will work with anything from Crome, Uberdata, Neptune, Hondata, whatever you want to run. (each was tested using a hondata s200)
ECU Pics
$110 for the P28 shipped
and $135 for the p72 shipped
edit: sold 1 lowered numbers
Modified by confidence at 10:18 PM 12/23/2007
Modified by confidence at 9:21 AM 12/26/2007
ECU Pics
bump for viewing
