Z6 or jdm D15b. ( help!)
Old Dec 23, 2007 | 07:06 PM
wernhersey's Avatar
Default Z6 or jdm D15b. ( help!)
I know that this is a broad topic but I need some quick help.
I am wondering what would be the easiest / most reliable build. Im looking into buying a 92-95 EX 4 Door. I was wondering if building a spare Z6 or building a jdm d15 would best to make a RELIABLE 300whp.
I know a block guard, new sleeves, valve train, rods, pistons, etc will be in the near future. I want to build this the right way. Then turbo it after its fully built.
I was just wondering which would be the easiest / reliable build.
Z6 or JDM D15?
-TIA
Old Dec 23, 2007 | 07:12 PM
SkoundrelUSA's Avatar
cute little bastard
Default Re: Z6 or jdm D15b. (wernhersey)
I've always perferred the Z6 because its just easier to get parts for. I know you can get all the stuff for a D15 too, but I hate searching to find out what parts work with it.
Old Dec 23, 2007 | 07:22 PM
hondaz6lx's Avatar
* B A N N E D *
if ur gonna build a motor find a z6
Old Dec 23, 2007 | 07:24 PM
singleslammer's Avatar
z6 would be best, and the easiest.
But, a lot of people have done vitara builds with a d15b usin z6 rods and vitara pistons, with a stock headgasket, and no clearance issues, so the choice is yours.
wicked_b16eg's Avatar
there basically the same motor.. ones is just jdm and the other usdm.
99% of the parts ar interchangable
It would be a flip of a coin.. lol GL
Old Dec 23, 2007 | 07:25 PM
z6hatchboy's Avatar
z6, theres always people posting threads trying to find what parts will work for their d15b's.
Old Dec 23, 2007 | 07:29 PM
Default Re: (z6hatchboy)
yea..
But in all reality the parts are interchangable. To find true d15b vtec parts is going to be hard but if you had a d15b vtec you could swap just about any part from a z6 and it would work just fine
Old Dec 24, 2007 | 07:04 PM
The only real differences between the d15b and the z6 are......
The pistons have the wrist pin located in a different spot
The water pump and the t-belt, use vx vtec-e ones
and the d15b uses a 1.5 block,
Several people have used a d15b to build and several have gone past 300whp with no problems.
Old Dec 24, 2007 | 07:14 PM
juall's Avatar
http://www.sohchonda.com/forum...11680
I believe the trouble with the d15b may be over once this kit is done. FJT solves the deck height trouble with a shorter rod and vitara combo. Good read.
Old Dec 27, 2007 | 07:52 AM
JDM_SOHC's Avatar
Default Re: (juall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juall &raquo;</TD></TR><TR><TD CLASS="quote">http://www.sohchonda.com/forum...11680
I believe the trouble with the d15b may be over once this kit is done. FJT solves the deck height trouble with a shorter rod and vitara combo. Good read.</TD></TR></TABLE>
and once that combo does become available D15B will oWn.. not that it doesnt already if built right....
cityofcaterpillars
Dec 18, 2017 06:14 AM
95CoupeDX
Feb 11, 2008 04:28 PM
Bimmer99
Jun 12, 2006 06:27 PM
dom5372
Feb 20, 2005 05:13 AM
CivicVX94
Jun 24, 2004 11:17 PM
