2 Problems *HELP*
Old Dec 23, 2007 | 06:23 PM
clintwsi's Avatar
Default 2 Problems *HELP*
First my front wheelbearings are making horrible noises. How difficult is it to replace them or should i have it done? (I have replaced my shocks/springs myself etc...)
Also i forgot the code but my check engine light came on, and i pulled the code and it was for the TDC (Top Dead Center) Sensor. I know that is for the #1 cylinder but that is all. I reset the ecu and it came on over and over. I need to replace it. Anyone ever had that done or know anything about please help me out. Thank you.
Old Dec 23, 2007 | 06:25 PM
z6hatchboy's Avatar
Get a manual maybe a service, but haynes may even cover it, and you should have the wheel bearing no problem. For the tdc code, maybe you have skipped a tooth in timing?
Old Dec 23, 2007 | 06:43 PM
DCSportEJ1Civic's Avatar
Default Re: 2 Problems *HELP* (clintwsi)
if you dont have your own press its gonna be pretty hard to do the wheel bearing. i took my spindle in to a local shop and they only charged a half hour labor to do it. it was like $25 plus the cost of the bearing.
Old Dec 23, 2007 | 06:45 PM
z6hatchboy's Avatar
^x2 forgot about the arbor press
Old Dec 24, 2007 | 06:09 PM
clintwsi's Avatar
Default Re: (z6hatchboy)
anyone know where to get the bearings online?
and we don't have any local tuner shops, so would a service shop, or tire shops be able to do this probably?
Old Dec 24, 2007 | 06:13 PM
z6hatchboy's Avatar
Service shop deff. would i dont know about a tire shop though. http://www.hondaautomotiveparts.com/ or http://estore.honda.com/asp/lo...=1248 should be able to get you the parts, or you nearest honda/acura for oem. Shoot adavance auto or equivalent would even have them.
Old Dec 24, 2007 | 10:05 PM
clintwsi's Avatar
is it a distributor cap or an actual whole distributor? i think i am finding 2 different types?
bertsb18hatch
Sep 15, 2007 04:01 PM
jdm206
Apr 28, 2007 12:18 PM
Tippyman
Mar 10, 2006 06:03 PM
JinksItR
Feb 13, 2006 02:24 PM
jccrxtuner916
Feb 12, 2006 10:32 PM
