gsr swap?? help
Old Dec 23, 2007 | 02:36 PM
kasperxtcy's Avatar
Default gsr swap?? help
i am helping my nephew swap in his 98 GSR i was wondering if i can use the ex engine harness?
Old Dec 23, 2007 | 02:55 PM
HAPRECYCLING's Avatar
what year car is it going in?
Old Dec 23, 2007 | 03:10 PM
kasperxtcy's Avatar
Default Re: (HAPRECYCLING)
97 civic hatch
Old Dec 23, 2007 | 04:42 PM
zuum's Avatar
Default Re: (kasperxtcy)
its not as simple as that... yes you can... but, some of the wires will be a bit short, you will have to lengthen then a little, you also have to add some wires, but it depends on what ecu you plan to use, to make this swap as easy as possible I would suggest using a chipped ecu... this is not a "simple" swap but can be done easily with some good technical info... better do a search since you are stuck at the harness. Good luck.
civicd15
Sep 10, 2010 11:22 PM
cup cake
Jun 23, 2010 12:26 AM
spunky424
Jul 23, 2006 07:18 PM
mrbsponge
12
Jan 25, 2004 08:08 AM
NOSpeed97
Aug 10, 2002 03:45 PM
