EG GSR oil leak
Old Dec 23, 2007 | 11:38 AM
eskerley's Avatar
Default EG GSR oil leak
Has anyone had a problem with a small oil leak coming from around the vtec solinoid? Mine is leaking and i replaced the seal and it didnt stop. Just wondering if anyone has had this problem and figured out how to fix it.
Old Dec 23, 2007 | 11:41 AM
sicones's Avatar
Default Re: EG GSR oil leak (eskerley)
it's probably from the cam seal
Old Dec 23, 2007 | 11:43 AM
z6hatchboy's Avatar
^x2 or v/c gasket
Old Dec 23, 2007 | 11:47 AM
HondamanXxX's Avatar
GO GIANTS!
Default Re: (z6hatchboy)
Winners!!!!!! ^^^^^
Old Dec 23, 2007 | 12:44 PM
eskerley's Avatar
Default Re: (HondamanXxX)
thanks alot i will check that out
Old Dec 23, 2007 | 12:55 PM
Mohsin's Avatar
Default Re: EG GSR oil leak (sicones)
not cam seal - Cam PLUG or also known as Cam Cap.
Cam seal is located on the Cam gear side of the camshafts.
I've just had the same problem and replaced both the cam cap and vtec solenoid gasket. Leak seems to have near enough stopped. Will post a bit later to confirm.
alacard
Apr 16, 2009 11:03 PM
itzyaboyzeem03
Nov 2, 2008 01:47 AM
del sol1658
Mar 4, 2008 12:04 AM
Out of every "game"
Apr 16, 2006 02:14 PM
