acura honda transmission d16a1 dohc sohc zc trans crx d
This transmission was is good running condition when taken out of 88-89 acura integra. It did not grind. It does have one bolt that seized and broke when it was taken off the car. It can easily be removed with the right tools or by a machine shop, or by being drilled out and tapped. You can see it in the pics...
This transmission is also commonly used in 1st gen crx's with the dohc zc or d16a1 swap.
http://cgi.ebay.com/ebaymotors...h=001
yeah, 1.347 according to here: http://www.g1teg.org/specs/
It has pretty awsome gear ratios acually, same as the hybrid zc, si combo. If that sites info is correct. (with the 4.214 fd)
d16a1, dohc, gear, interchangeable, place, put, ratio, sohc, tranny, trans, transmission, transmissions, vtec, with, zc
