squealing noise
Old Jun 28, 2002 | 06:19 AM
B18C-RnVA's Avatar
New User
Default squealing noise
i have a b18c1 and everytime i start my car it sounds like my belts are squealing. or when im driving and down shift it squeals again. i want to say my its the belts, what can i do to fix this. the noise is getting on my nerves.
Old Jun 28, 2002 | 06:23 AM
YeuEmMaiMai's Avatar
Default Re: squealing noise (B18C-RnVA)
the auto tenssioner should take care of the belt tension. if you have a 2 belt design, the alt is the adjustment for the second belt..
Old Jun 28, 2002 | 01:46 PM
B18C-RnVA's Avatar
New User
Default Re: squealing noise (YeuEmMaiMai)
so there is nothing i can do about that noise,,
Old Jun 28, 2002 | 02:21 PM
slooowDX's Avatar
its you're alternator belt most likely...check if its loose, if it is then tighten it up, or better yet, while you're down there...just change it, its not that expensive
Old Jun 28, 2002 | 04:14 PM
S13 slide's Avatar
well if it aint your belts it could be your water pump or need ps fluid, those are some other things that squeel
Liquidice944
Honda Civic (2001 - 2005)
15
Aug 17, 2009 04:24 PM
GSRpoweredSI
Jun 20, 2007 01:13 PM
Sam268
Jun 10, 2004 06:10 PM
