knock sensor problem
Old Dec 22, 2007 | 11:45 PM
MONSTERek4's Avatar
Default knock sensor problem
ok i have a 97 civic cx with a 99-00 b16a2 complete change over my harness was made by hook-ups now known as whitfield racing. here is my problem i was driving my car going 120 mph one night the next morning it threw code 23 which is knock but my motor is not knocking. so i thought it was a bad knock so i changed it but it still throws the same code so i got a new dizzy and still samething but the motor some what backfires but just a lil im running a 98 spec itr computer
Old Dec 23, 2007 | 12:23 AM
poison's Avatar
Default Re: knock sensor problem (MONSTERek4)
I would suggest grabbing a multimeter and checking the wiring.
Does your engine sound healthy?
Old Dec 23, 2007 | 12:28 AM
MONSTERek4's Avatar
Default Re: knock sensor problem (poison)
no it does not sound healthy you can berly hear vtec
Old Dec 23, 2007 | 02:18 AM
MONSTERek4's Avatar
ok should i run the wire direct or what
Old Dec 23, 2007 | 05:11 PM
MONSTERek4's Avatar
ok i ran the wire direct and still code 23 what the hell the motor sounds real good right before code 23 it takes about 2 minutes to go on
Old Dec 23, 2007 | 05:17 PM
z6hatchboy's Avatar
Do you have access to the ecu for that motor? Im thinking some had a problem like this before, and a bunch of people said get the right ecu, do the itr's have diff. ignition table than b16a2 ecu's anyone?
Old Dec 23, 2007 | 05:24 PM
MONSTERek4's Avatar
Default Re: (z6hatchboy)
it was running find for like a week and out of no wher expletiveing poof the cel came on
Old Dec 23, 2007 | 05:28 PM
z6hatchboy's Avatar
Oh ok, better stick to poisons answer then.
Old Dec 23, 2007 | 06:30 PM
MONSTERek4's Avatar
so maybe the pin is bad or what
Old Dec 23, 2007 | 06:32 PM
z6hatchboy's Avatar
Check for shorts on the knock sensor wiring and while your at it inspect the connectors.
Old Dec 23, 2007 | 06:58 PM
Reef188's Avatar
Check the pinout on the ecu...pretty sure its not the same as stock so it would have had to been moved..make sure its pushed all the way in on the clip at the ecu because ive had them pop out on me and would work sometimes and other times they wouldnt!!
Old Dec 24, 2007 | 12:12 AM
MONSTERek4's Avatar
Default Re: (Reef188)
ok here is the follow up i put a new plug and still knock and checked pin out
02spoon
Oct 17, 2010 09:48 AM
sir2sol
Apr 1, 2005 04:55 PM
roadawg
Feb 11, 2004 01:10 PM
speshuled619
Jul 26, 2002 10:23 AM
Chris_
Apr 15, 2002 07:01 AM
