MY IDLE GOES UP AND DOWN AFTER THROTTLE BODY CLEANING
1994 accord lx auto, i just put in some new ngk spark plugs and changed the gasket sealent because it was leaking oil into the spark plugs, i decided to clean the throttle body, so i did, and now my idle is revin up and down only in park, on its own and blue smoke coming from the tail pipe, and in gear the idle is at 1000 my friend told me its normal bacuse of the throttle cleaner, and it would go away?
Try reseting your ECU. pull the backup fuse or disconnect the battery (-) terminal for 30 seconds.
If you are still having the idle surge problem after resetting your ECU. You should check for vacuum leaks and cleaning your IACV & FITV.
Pashpacino
Engine Management and Tuning
Mar 13, 2018 06:23 PM
phelpsj2
Nov 3, 2011 02:35 PM
bmxfelon420
Mar 20, 2010 04:11 PM
ridin98civic
10
Feb 2, 2007 11:11 AM
