Question Do you still sand down body to put primer on?
Old Dec 22, 2007 | 03:26 PM
JustHere4ADay's Avatar
WHEEL Slayer
Default Question Do you still sand down body to put primer on?
Can i just throw it on or do i still have to sand it down? and what grit do i get?
im 100% noob when it comes to body work
Old Dec 22, 2007 | 04:21 PM
Boost'd EJ1's Avatar
Default Re: Question Do you still sand down body to put primer on? (JustHere4ADay)
u must sand first so the primer or paint has something to grab to or it will just peel rite off.
Old Dec 23, 2007 | 07:22 AM
Costco's Avatar
Default Re: Question Do you still sand down body to put primer on? (Boost'd EJ1)
Yep, always sand with the appropriate grit prior to applying primer.
Old Dec 23, 2007 | 09:45 AM
Pockets's Avatar
why are you priming? the only reason you need to prime is if you have exposed filler. if you're priming that it's sanded already. but you do need to take 180 grit on a DA and sand out all the hand sanding 180 marks around the filler. after the 180, use some 320 and go a few inches around your 180 DA marks so the primer has something to land on.
d16trexin
Paint and Body
Apr 16, 2009 05:21 PM
-16V-
Paint and Body
Mar 15, 2009 06:35 PM
jacobforcecrx
Jul 26, 2005 08:50 PM
05member y0
Jul 24, 2005 07:10 PM
