tires
Old Dec 22, 2007 | 12:40 PM
globy123's Avatar
Default rotating tires
Hi. I have a 99 Civic LX and I am due for a tire rotation. What is the best method to rotate tires? Front to back and leave them on the same side or cross them from one side to another, front to back?
Modified by globy123 at 9:10 AM 12/27/2007
Old Dec 22, 2007 | 12:44 PM
ddd4114's Avatar
Default Re: tires (globy123)
Just front to back
Old Dec 22, 2007 | 12:48 PM
Cln94EG1's Avatar
Default Re: tires (ddd4114)
Here Ya go
Old Dec 22, 2007 | 12:50 PM
globy123's Avatar
Default Re: tires (cln92eg)
image doesn't work
ddd4114's Avatar
Just to clarify: I said front to back to be on the safe side. You didn't say what type of tires you had, so I assumed they were unidirectional.
Old Dec 22, 2007 | 12:52 PM
Cln94EG1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 &raquo;</TD></TR><TR><TD CLASS="quote">Just to clarify: I said front to back to be on the safe side. You didn't say what type of tires you had, so I assumed they were unidirectional.</TD></TR></TABLE>
you can still rotate them from the back to front then the back goes left rear goes to right front and right rear goes to left front thats how we do it at work. Heres the site
http://www.tirerack.com/tires/...id=43
Old Dec 22, 2007 | 12:54 PM
globy123's Avatar
How can I check if I have unidirectional tires?
Old Dec 22, 2007 | 12:56 PM
Cln94EG1's Avatar
It will say on them, Or show a arrow pointing one way only, Tell me the tires u have and i can tell you if they do or dont
Old Dec 22, 2007 | 01:31 PM
SpeedoKing's Avatar
if they are directional then they have to go back to front on the same side (Ex. back left to front left) they can also be tires that have to be rotated from front left to front right (idk the name but they are rare and you would probably know if you have them) if they are jus regular all season tires then you would rotate them back left to front right. all this information should be found on the tire wall if you are not sure then jus take it to a tire shop it souldnt cost more than 20 bucks to have done and then you know it is done right.
Old Dec 25, 2007 | 10:10 AM
globy123's Avatar
Default Re: tires (SpeedoKing)
Hi guys. I had a chance to look at the tires today and it doesn't say anything if they are unidirectional or bidirectional. This is all the information on the tires:
Firestone
P185/65R 14 85S M+S
Tubeless Radial
K19R
FR680 02
Treadware 440
DOT W17J
F60 1704
Max PSI:44
Traction A
Temperature B
Can someone tell me how I should rotate my tires? What's the best method?
Modified by globy123 at 9:04 AM 12/27/2007
Old Dec 26, 2007 | 04:12 PM
globy123's Avatar
bump
Old Dec 27, 2007 | 08:03 AM
globy123's Avatar
Old Dec 27, 2007 | 09:02 AM
EL Vap133's Avatar
Do you have the manual for the car?
Old Dec 27, 2007 | 10:44 AM
globy123's Avatar
Default Re: tires (EL Vap133)
I have the pdf version of the manual and I was searching for information on tire rotation methods but could not find anything.
Old Dec 28, 2007 | 07:03 AM
globy123's Avatar
bump..Anyone???
Old Dec 28, 2007 | 07:17 AM
Probot's Avatar
dude if you dont know how to rotate your tires just go to a tire shop and have them do it...
Old Dec 28, 2007 | 07:39 AM
mckrank313's Avatar
Default Re: tires (Probot)
front to back and vice versa... don't worry about switching sides of the car while rotating no real need for that just switch the front left with the rear left and the right front with the right rear tire
i'm 99.9% sure those tires are for one direction so i wouldn't switch the sides on them
Old Dec 28, 2007 | 07:42 AM
-Gary-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Probot &raquo;</TD></TR><TR><TD CLASS="quote">dude if you dont know how to rotate your tires just go to a tire shop and have them do it...</TD></TR></TABLE>
He wants to learn how to do it. Don't hate on someone trying to do the right thing.
greenEFSI
Dec 19, 2006 06:26 PM
da_33
Dec 14, 2006 03:56 PM
CRISIS
Jun 28, 2006 08:46 PM
config
Sep 21, 2003 07:22 AM
