header temperature?
does anyone know how hot a set of headers might get in typical street use?
i only ask because the header i just picked up needs a new heat coating. i was looking into por-20 which is good for 1400 degrees.
then again most off the shelf stuff is only good to about 1500 unless you go with swaintech or jet hot or the like.
any input? thanks
any input? thanks
eightvalver
Apr 8, 2006 09:11 PM
fireant
May 1, 2005 09:18 AM
20, accord, header, headers, headershondatemperature, heat, honda, por, spray, temerature, temp, temperature, temperatures, thermal, typical
But honestly I would think 1100-1400 under a load
