i missed 4th gear and went into sec..
Old Jun 27, 2002 | 10:35 PM
riceking3's Avatar
Default i missed 4th gear and went into sec..
i was racing my friend and i was going and i try to shift into 4th but i missed and went into 2....but i let go of the gas really quick
it looks like no damage but can some help me up with some answers
94 GSR
Old Jun 27, 2002 | 11:11 PM
andwutgsr's Avatar
Default Re: i missed 4th gear and went into sec.. (riceking3)
i did the same thing.. but i popped the clutch... redline went allllll the way to the very last red marking.. i melted my valves.. got a new motor tho. dont u just love it when your car is still under warranty
Old Jun 27, 2002 | 11:15 PM
Evil EG's Avatar
I did the same thing about two months ago also. I ended up bending my valves. Then I went and got skunk2 valves crower springs and retainers and skunk2 cam gears all put on and the total bill was $1,700 (also included was arp head studs and honda oem head gasket.)
Old Jun 27, 2002 | 11:18 PM
riceking3's Avatar
Default Re: i missed 4th gear and went into sec.. (andwutgsr)
i didn't go past 9 thats the thing .. i have a p28 so i ihad to shift at 7 and when i missed it when to 9000 rms no mor no less
Old Jun 27, 2002 | 11:36 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
9K RPM? and i'm assuming you've got an GSR. i'd say it's f*cked (8K redline... thats a little more than the hodna "slack" gives you)
[Modified by dLo GSR, 12:37 AM 6/28/2002]
Old Jun 27, 2002 | 11:49 PM
aznmc16's Avatar
Default Re: i missed 4th gear and went into sec.. (dLo GSR)
i did the same thing with my 94GSR just last week... i wuz gettin on teh freeway and saw a few cars zooming prety fast.. to make things short.. i tried to catchup... i missed 4th and hit 2nd gear and hit like 9500RPM for about 1/4 a second... it was some scary ****.. nothing wrong with my motor tho.. whew~!!!!
Old Jun 28, 2002 | 01:35 AM
initialR's Avatar
Default Re: i missed 4th gear and went into sec.. (aznmc16)
I did the ame thing at the track shifting to 4th but missed ran a 15.2 but scared the **** out of me
Old Jun 28, 2002 | 04:17 AM
MrBite's Avatar
You guys need to stop shifting kung-fu style. It shouldn't take a lot of force to change gears. Don't try to force it if it doesn't go, that's how stuff gets broken. And if you miss 4th and hit 2nd, you definitely need to slow down--the 3-4 shift is the path of least resistance!
Old Jun 28, 2002 | 05:16 AM
EJ8 Kenobi's Avatar
Default Re: i missed 4th gear and went into sec.. (MrBite)
once I almost did that (stereo was too loud) but my car actually wouldn't even let me get it into 2nd, it just grinded to hell.. I couldn't do it if I wanted to
Old Jun 28, 2002 | 05:32 AM
X2BOARD's Avatar
Default Re: i missed 4th gear and went into sec.. (FrankGSR)
B series motors are rock hard... I've 9 pegged an LS with no damage.
Is the car ticking at all ? I would recommend you do a valve adjustment to keep everything tight. If you really want, you can pull the head to inspect the valves, it'll cost you a headgasket and labor if you need to pay for it.
X2
Old Jun 28, 2002 | 05:33 AM
TGUNNER's Avatar
AHAHAH NEVER SLOW DOWN YOUR SHIFTING BOYS AND GIRLS!!! MAKE IT FSATER!!!!
Old Jun 28, 2002 | 06:39 AM
WOTTEG's Avatar
Default Re: i missed 4th gear and went into sec.. (BVM)
BVM:
What do bent valves sound like? Is it the ticking that X2BOARD describes?
I hear a slight (and inconsistent) ticking in my engine (For about 1300 miles now). The ticking is proportional to RPMs when I hear it.
I had the valve clearances adjusted to spec, but the noise is still there.
Please share your insights BVM and X2BOARD.
Thank You.
ENGINE SPECS:
2000 LS (B18B1)
33k Miles
Valve Clearances adjusted to spec @ 32k Miles
AEM CAI w Bypass
Moroso Catch Can
[Modified by WOTTEG, 7:45 AM 6/28/2002]
Old Jun 28, 2002 | 07:45 AM
GSRwBOOST's Avatar
Yea.. seems like someone needs to work on their shifting skills...
I love the guys who lean forward and when they shift to second or fourth they throw their weight into it.....
Old Jun 28, 2002 | 08:00 AM
Nick's Avatar
Default Re: i missed 4th gear and went into sec.. (GSRwBOOST)
Not to be a smartass or anything, but how does one put a car in second (thinking it's fourth) when your in third. Doesn't make any since even when racing or whatever...
Old Jun 28, 2002 | 08:36 AM
GSxRated's Avatar
Default Re: i missed 4th gear and went into sec.. (Nick)
Actually its not that uncommon, look at all the people that replied to this one post saying they've done it themselves. I did it at the track earlier this month, made a loud *** sound but nothing seems to be wrong. Only thing that pissed me off is I would've broken into 14's if that wouldnt have happened, ran a 15.1.
Old Jun 28, 2002 | 08:46 AM
JL 74's Avatar
TRUE. I couldn't agree more. Everytime I see these "mishift" threads, I am like, how the hell do you misshift? You really have to try to miss your gear. Don't try to "guide" them into the gear (like the notches in Ferraris). From 5th to 4th, just pull it down nicely. DON'T guide it to the left then down, just pull it down.
Old Jun 28, 2002 | 08:48 AM
Tweakmeister's Avatar
it's actually pretty easy to do something like that, it's not uncommon under "spirited driving sessions"
build something idiot proof and you'll find a better idiot
Old Jun 28, 2002 | 08:56 AM
Fooser's Avatar
Default Re: i missed 4th gear and went into sec.. (Tweakmeister)
How do you guys always miss 4th and hit second? Are you new drivers or something? from third its straight back not back and to the left. Why dont you practice a lil more on shifting before you think you can race.
Be more carefull then things like this wont happen. I think the worste thing I have ever done is let the clutch out too fast. I cant see hitting second shifting from third tho.
If you just pull the clutch to neutral it automatically goes to middle which is above 3rd and 4th gear. straight back fellas straight back.
Old Jun 28, 2002 | 09:45 AM
sutrusu's Avatar
Default Re: i missed 4th gear and went into sec.. (Fooser)
what the hell?! you have 5 speed transmissions! you really have to TRY to misshift on a 5 speed gearbox...
Old Jun 28, 2002 | 10:16 AM
Evil EG's Avatar
Default Re: i missed 4th gear and went into sec.. (WOTTEG)
BVM:
Thank You.
ENGINE SPECS:
2000 LS (B18B1)
33k Miles
AEM CAI w Bypass
Moroso Catch Can
When I misshifted I heard a little bang. Then my check engine light came on. My car started idling really weird and the RPM's would fluctuate between 100 and 2000 RPM's, also when you opened the hood while the car was idling you could hear a faint *tick* like the second hand of a clock.
Old Jun 28, 2002 | 09:19 PM
EJ8 Kenobi's Avatar
I did it once, my excuse, the bushings in the shift are bad
Old Jun 28, 2002 | 09:31 PM
-Darren-'s Avatar
the reason why some people end up going from 5th to 2nd is because there gearbox is set up where reverse is under 5th and they are afraid that they might go into reverse, unlike german cars where reverse is up by 1st gear .
Old Jun 28, 2002 | 09:44 PM
AWD: Jeff's Avatar
Default Re: i missed 4th gear and went into sec.. (blkgti)
didnt miss shift, but shift to hard and broke my short shifter.
Old Jun 28, 2002 | 09:49 PM
samagon's Avatar
if you are worried, get a compression test, that will give you all the answers you need
Old Jun 28, 2002 | 09:56 PM
V-Grip! Teknic73's Avatar
who cares.....why are you posting stupid ****......does your car run, thats all that matters!
