differential oil question
Hi, what brand of oil do you use in your rear differential??
I'm planning to change mine and I don't know what to use.
And how many quarts must I use?
Also for the transmission, what brand and how many quarts of oil do you use??
Thank for the help!!
If you don't want to go OEM, you have a few choices:
Redline 75w90
Lubrication Engineers LE607 Almasol
Royal Purple GearMax, same as above, different bottle.
Redline 75w90
I just replaced mines on ap2 with mobil 1 75w fully synthetic or blue bottle, I used most of it. But you will need a 23mm wrench for the fill bolt, no socket I had would fit...
drain is 24mm get some kind of pump too if you diy
svhiker
Aug 4, 2017 03:19 PM
