Problem with my syncrowave 200.
Old Dec 21, 2007 | 09:52 AM
narfdanarf's Avatar
Default Problem with my syncrowave 200.
When I let off of the pedal sometimes it doesn't stop the arc. It seems like its maybe a contact issue inside the pedal. The machine is brand new, like only used 1 time new. I thought I would post up here first before calling Miller/Cyberweld just in case I am retarded and there is some sort of setting or something that is jacked up?
Old Dec 21, 2007 | 12:03 PM
onefstek's Avatar
you should allways let off the pedal slow to termitate the arc.
but if your foot is all the way off and the arc is still going, then the micro switch in the pedal is screwed up.
Old Dec 21, 2007 | 12:28 PM
narfdanarf's Avatar
Default Re: (onefstek)
yeah that's what I do, and when the pedal is all the way out, it's still arcing, so I have to tap the pedal like 10 times to get the arc to stop. I figured it was an internal issue.
Old Dec 21, 2007 | 12:29 PM
onefstek's Avatar
what size tungsten do you use and what is your apms at?
also how do you sharpen your tungsten?
Old Dec 21, 2007 | 01:28 PM
narfdanarf's Avatar
3/32" I've tried all kinds of amperages on all kinds of different metals. some aluminum sheet, some 1/4" carbon steel plate, Nickel Copper pipe. It does it every time, which is why I thought it might be a setting on the machine I just wasn't aware of, I'm gonna try and get a new pedal or get mine fixed. I grind the tungstens to a blunt point, grinded area 15* angle, and about 3/16" long.
Old Dec 21, 2007 | 01:57 PM
onefstek's Avatar
Read the manual and see if you have the adjustments set right.
There is a setting where you can ajust for arc for "soft" "midium" or "hard" on how fast it arcs.
Old Dec 21, 2007 | 04:11 PM
RCautoworks's Avatar
Default Re: (narfdanarf)
I just got my peddle fixed on my 200, I think two weeks ago. A wire was cut inside.
Old Dec 21, 2007 | 04:47 PM
narfdanarf's Avatar
Default Re: (RCautoworks)
I took it apart and just bent the little tab that actuates the micro-switch. Works like a champ now!
Jaynik
24
Aug 26, 2021 05:37 PM
arziffel
Apr 16, 2012 05:27 PM
quantum_05em2
Honda Civic (2001 - 2005)
Mar 12, 2008 08:37 AM
lYellowDragonl
Jul 22, 2004 10:13 AM
