passenger door locking mech,
Old Dec 21, 2007 | 09:13 AM
RACEPAK's Avatar
Default passenger door locking mech,
sup everyone.
i have this problam for a while now and i need some help to solve it,
car: 97 hatch
symptoms:
-my passanger door isnt allways locking/unlocking when i lock the driver's door (manualy and/or with the remote)
-somtimes when the alarm is disengaged the door locks and unlocks itself (key off and key on, and with no key)
i checked all the connectors inside the door and cleand them.
any ideas?
thanks
Old Dec 21, 2007 | 09:38 AM
B18C_EJ8's Avatar
Did you clean the grime out of the little nylon pivot points inside the door that are attached to the lock rods?
Old Dec 21, 2007 | 10:25 AM
RACEPAK's Avatar
Default Re: (B18C_EJ8)
nope....
Old Dec 21, 2007 | 10:28 AM
B18C_EJ8's Avatar
Then you should <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">clean the grime out of the little nylon pivot points inside the door that are attached to the lock rods</TD></TR></TABLE> and make sure that the lock rods move up/down/side to side freely.
I've had to clean mine a bunch of times, because they will bind up again. Poor design maybe?
I've found that white lithium grease helps prolong the intervals between cleanings.
Old Dec 21, 2007 | 12:37 PM
RACEPAK's Avatar
it dont think its the issue, its an electrical problam, (i thought you ment the grime on the door main connector)
Hawjap1gsr
Jul 21, 2010 09:18 PM
B20inDCinLBC
13
Apr 21, 2009 10:28 AM
callmetree19
Jun 29, 2008 02:17 PM
datssoled
Sep 28, 2006 07:30 PM
zoolander
Mar 5, 2006 08:22 PM
