H-t suspension setups
please post the setup you are running. Also include what its on and what type of driving the car mainly sees. Also if it is a drag setup post your 60 ft times too. It would be interesting to see what everyone is running. Thanks
My setup: Koni Yellow's, GC Coilovers (350F/450R), Function 7 LCA's, Function 7 Swabar Endlinks, and Energy Suspension bushings everywhere except the Trailing Arm. I'm riding fairly low, tires are BFG's 205/50/15 and im slightly tucking tread.
I'm also waiting on an ASR Subframe Brace and ASR Swaybar.
I haven't perfected the shock settings yet, but i'm very happy with the performance so far. The car has never been to the strip, so I have no times for you. I drive on the street, and would love to get into Auto X. With the stiffer springs in the rear, it is a very predictable car. Doesn't understeer at all, and if the rear is going to break loose, you know before it happens. It just rotates perfectly. I have absolutely no problems bottoming out the shocks, and the UCA's do NOT hit the shock towers at all - even as low as I am.
ksport with the default 10/6. too harsh for daily driving, but hopefully i can get it dialed in for the season. 205/50/15 potenza g009 daily, 205/50/15 bfg sports for autox. g009's are a bit loud, but my car is stripped which doesnt help.
99 civic coupe
GC & skunk 2 springs (500/450)
tokico illuminas
ST rear swaybar & subframe brace
Omni-power front UCA
omni-power rear LCA
omni-power rear camber kit
SRR rear toe kit
J's Racing roll center adjusters
korbach frame locks
password: jdm front and rear strut bars
megan H brace
used to run 205/40/17 azenis rt-615s, but once spring comes it will be on 205/50/15 hankook rs-2
i drive this everyday, go to every auto-x i can, and it hits the track a couple times a year.
tokico illuminas
omni-power rear LCA
SRR rear toe kit
korbach frame locks
megan H brace
waiting to get koni yellows, or tokico illuminas. blue blox lca's...
