93 civic coupe LS/Vtec Turbo Fully built 10k OBO complete or part out
Old Dec 21, 2007 | 02:46 AM
DaveF's Avatar
Default 93 civic coupe LS/Vtec Turbo Fully built 10k OBO complete or part out
parting out
add'd more items as of 12-27
* HaSport Motor Mount Kit (cable/hydro conversion kit) 250.00
* B18A Golden Eagle 83mm sleeved with copper o-ring 900.00 + shipping
* ARP head studs(GSR) 65.00 shipped
* Golden Eagle Vtec conversion kit 150.00 shipped
* Crower Billet Rods 450.00 shipped
* Arias Pistons 83mm 10.0:1 compression(flat top) 300.00 shipped
* Type R Oil Pump 50.00 shipped
* Gsr Water Pump 50.00 shipped
* Moroso Oil Pan 225.00 shipped
* Moroso Oil Pump Pickup (with pan)
*B17A Vtec Head complete head(no intake mani/ comes with oem black valvecover) 800 + shipping
* gsr cams
* Skunk2 Racing Valves
* Skunk2 Titanium Retainers
* Skunk2 Racing Valve Springs
* Skunk2 Intake Manifold 150.00
* ITR valve cover 120.00 shipped
* Str sparkplug cover 75 shipped
* Griffin Radiator w/ FAL Fan 250+ shipping
*Rev Hard Short Tubular Turbo Manifold (t3 turbine flange/tial 40mm wg flange) 225.00
*3inch Downpipe for above manifold 150.00
* 3inch Full Exhaust with Apexi N1 canister 300 + shipping (jet hot coated)(fits civic coupe)
* Tial Wastegate 40mm 200.00
* Turbonetics T3-T04e Turbo ( To4e-50trim compressor/STG III Turbine Wheel/ .63 AR) 450.00
* Apexi Front Mount (same size as Precision turbo 750hp core) 500.00
* 2.5inch Jet Hot coated Intercooler piping w/silicone couplers & T bolt clamps 250.00
* Greddy Type R Blowoff Valve 200.00
* Greddy TVVC Boost Controller 200.00
Suspension
* Skunk 2 Drag Launch Coilovers 200
* Skunk 2 Front Camber Kit 100
* Tokico Illumina 5 way adjustable shocks (shocks and drag coilovers together for 450)
* Lakewood Traction Bar 100+ shipping
* eibach front and rear sway bar kit with endlinks etc, i belive its everything for installation. brand new in box, make offer ?
* 15x6.5 Konig Traffik wheels with 205/50/R15 Falken Azenis 600.00
* Accel Gen 7 DFI with harness distributor and sensors(GM 3 Bar map/GM intake temp/GM ect) 1300.00 PLUG AND PLAY, plugs into your oem honda harness !!!!
* Crane Ignition HI-6 with LX-91 External Coil 250.00
* RC Injectors 720cc 200 shipped
* Aeromotive Fuel Pressure Regulator 100 shipped
* Aeromotive Fuel Filter 50 shipped
* Aeromotive A1000 Pump 225 shipped
* Stainless Braided -6an Fuel hose and fittings (runs from sumped tank to pump to fuel rail and back) 150 shipped
* OEM gas tank with competition engineering sump 200.00 (MUST PICK UP)
* JG/Edelbrock 65mm Throttle Body 150 shipped
* STR Fuel Rail 100 shipped
* LS cable Transmission (small spline cable) with Quaife LSD 750.00 + shipping or you pick up.
* B16 hydro trans (all stock) 650.00 + shipping
* Clutch ACT 6 Puck clutch 200 shipped (i belive this is with a heavy duty pressure plate)
* ACT Streetlite Flywheel 150 shipped
* TCI Axles 150 shipped
* Integra Rear Disc Conversion with Powerslot rotors & hawk pads
200.00 picked up
* Integra rear disc conversion 150.00 (yes i have 2 rear disc conversions)
* Greddy Boost Gauge 75.00 shipped
* Greddy EGT Gauge 75.00 shipped
* Greddy Oil Pressure Gauge SOLD SOLD SOLD
* Autometer 3 3/4inch Sport Comp Tach 75.00 shipped
* Apexi Autotimer 75.00 shipped
<FONT SIZE="5">MORE FORSALE PARTS </FONT>
AEM 1020 ECU setup for cam trigger kit - 900.00 shipped
Raychem'd wire harness w/relays - 1000.00 shipped
* All "solid" wires, NOTHING IS Soldered
* All new terminals and connectors
* Tefzul mil spec wire used
* Duetsch mil spec connectors throughout
* all of the wires are twisted back to the ecu
* set up for 8 injectors, gm intake temp, AEM 150 fuel psi sensor,AEM 5 bar map, Hall sensor for vehicle speed
* includes wiring pinout/diagram
__________________________________________________ ___
__________________________________________________ ____
T1 sensor kit with Golden eagle cam gears - 650 shipped (raychemed harness, duetsch connector)
AEM 150 PSI fuel pressure sensor - 125.00 shipped
AEM 5 Bar MAP - 125.00 shipped
M&W Prodrag 4 IGN box(coil on plug, more powerful than the pro14) 750.00 shipped
IGN coils, mounting bracket, & spark plug wires - 300.00 shipped (coil on plug)
NGK wideband 200.00 shipped (raychemed harness)
NLR boost controler 825.00 shipped (wire harness is raychemed/duetsch connector/ quick disconnect fittings and rubber mounting cusions on solenoids and 5 bar map)
Rob Moore Performance / Nitro Driveline spindles
Spindles with bearings and ball joints
800 shipped these cost 1500 new !!!!
Mark Williams Spool
* fits mark williams axles for honda B series, may fit others but i dont know
500.00 shipped
__________________________________________________ ________
b16 hydro gearset with circuitworx 4.7 final drive and liberty's gears handcuff
* all syncro hubs + sliders are in great condition, transmission never let me down, shifts like a champ!
* includes top bearing for main shaft(it was stuck in top of case during pics)
1150.00 shipped minus shift forks/mechanism/casehalves
1300 shipped with BOTH case halves/shift levers/mechanisms, all bolts(everything but a LSD or spool)
<U>Innovative mounts for EG chassis</U>
* anodized black, billet aluminum mounts with the grey "race durometer"
Brand NEW
350.00 shipped
<U>aluminum intercooler piping kit</U> 2.5inch (has no blow off valve flange) BRAND NEW !
225.00 shipped
EG coupe shell (red)
* 94-01 integra interior (dash, cluster, center consol, ITR armrest, integra heater core/blower assembly, integra front seats, integra black carpet)
* comes with EXTRA integra front brakes/subframe/spindles/upper and lower control arms, rear disc conversion, 1inch master cyl + the matching booster
* car is sitting on stock teg suspension, steelies, needs front bumper and door panels
asking 1500.00
<U>Turbonetics T-66 ball bearing</U>
* T4 turbine (comes with .81 and .58 housings)
* 4inch compressor inlet/2.5inch outlet with 90 degree elbow welded on
* included is v-band weld flange and clamp for downpipe.
1000.00 shipped
__________________________________________________ ______________
Oil Catch can
* fits 1-3/8 filter
* -12 an male bung
* 1/4npt drain/plug
10 inch tall coil springs
* fit 2.5inch shock
* 650lb rate
* brand new
75 shipped
* fits 2.5inch shock
* 350lb rate
50 shipped
Modified by DaveF at 10:08 PM 12/28/2007
Old Dec 21, 2007 | 10:50 AM
DaveF's Avatar
Default Re: 93 civic coupe LS/Vtec Turbo Fully built 10k OBO complete or part out (DaveF)
up
Old Dec 22, 2007 | 02:18 AM
DaveF's Avatar
Old Dec 22, 2007 | 10:25 AM
turboacurab20's Avatar
i have a 94 integra and a 92 chevy 1500 pickup id trade or i mightbe interested in motor and tranny acurageorge@aol.com
Old Dec 22, 2007 | 11:02 AM
DaveF's Avatar
Default Re: 93 civic coupe LS/Vtec Turbo Fully built 10k OBO complete or part out (turboacurab20)
pm sent
Old Dec 23, 2007 | 10:18 AM
DaveF's Avatar
up
Old Dec 27, 2007 | 11:23 AM
DaveF's Avatar
up
EJ8chu
Mid-Atlantic (Sales)
Aug 17, 2014 04:29 AM
SAXON
Oct 12, 2011 01:49 PM
DaveF
Dec 23, 2007 02:17 PM
Funkin Flux
Sep 25, 2005 11:48 PM
