BADASS GARAGE SALE!! YOU GOTTA SEE THESE PARTS!
BUMP THIS IF YOU VIEW IT!!! PLEASE!
prices without shipping
NEW PICTURES AND NEW STUFF ADDED!!
FOR SALE:
B16 LSD tranny - 950 - ITR LSD
Turbo Stuff!! ------>
-used 2 inch coupler - 3 with clamps
-used 2.5 inch turbo coupler - 3 (might have some clamps for this one... not sure)
-Apexi Turbo and NA timer - old skool - 40 obo
-Dual Gauge pod for EK pillar- 10
-38mm TIAL wastegate - 180 obo
Aftermarket parts ----- >
-Bseries stainless DC sports header - 175 obo
-WICKED Eg rear toe kit - 80 obo NIB
-INFINITY speaker covers - 10
-BRIGHT RED VTEC VALVE COVER (freshly powder coated - MUCH brighter than ITR) - 130 or 100 plus a stock valve cover
-AEM CIA for EK/EG blue in color like new condition - 120 obo[/b]
ECUs ------->
-OBD2 - OBD1 wiring harness - 60 obo
**JDM OBD1 socketed p30 (needs a chip) - 120 obo
OBD2 P72 - 65 obo
Audio
-Two JL 12 inch subs in a carpeted box - 150 obo
-Carpeted box for two 10 inch subwoofers - 35
-CD player - (will not play sound unless hooked up to an amp! only the RCAs work! comes with remote) - 40
B series PARTS--------->
-GSR HEAD STUDS (stock)- 15
-Stock tranny side GSR mount - 25 obo
-MAP sensor - 5
-GSR stock intake manifold - 35
-Bseries Speedo Sensor (VSS) - 30 obo
-B series working thermostat - 5
Gsr timing covers - (USDM or JDM) - 75 obo for the JDM cover, 55 obo USDM (i have two JDM ones!!)
D series stuff --->
-D series flywheel - 20 obo (i have two!!)
-D series alternator - 20
-Dseries starter - manual - 20
-D series driver side two bolt mount - 5
More stuff----->
-Spoiler for rear hatch glass - EG - 40 firm (painted blue JDM yo!)
-Blue eg steering wheel with airbag - 10
-stock springs from civic - 10
-fresh Frost white painted hatch door (one fist sized dent and multiple little ones) - 10
-passengar teggy caliper - 10
-GSR rear LCAs - 35 ( one has NO BUSHINGS!! great for poly urethane setup!! the other one still has good bushings in it!)
-Bright blue stock color gas door for EG - 10 obo
-EG coupe teal gas door - 10
-EG wiper arms - 10
-Black door handle covers for EG - 5
-Eg drivers side corner - Clear (aftermarket) - 5
-EG driver side corner - amber - 5
-EG front upper control arms - 15
-EG HATCH rear 1/4 panel windows - 40 each or 70 for both sides
REAR DISC BRAKE SWAP (includes e-brake lines but no rotors) - 170 obo
-manual window crank for EG - passenger side - 10
-EG sprayer tank and motor - 15
-Civic shift boot - 3 or free if you buy more stuff!
Exhausts---->
-straight pipe + 2.5 inch exhaust for eg hatch or coupe - 35 - will bolt up, but needs welds. SOMEONE BUY THIS.....its an exhaust for 35 dollars!!
CRX &EF & DA - obd0 parts ------> - All the OBDo stuff - 40 dollars!
-CRXsi visors - 10 obo
-ls power steering pump - 20!!
-Black CRX fuse box cover - 10
-CABLE!!!! b16 transmission outer casing - 40 obo
VW parts ----->
(stock parts from my 2000 GTI GLX)
-passengar side headlight - 65 obo
-drivers taillight - 55 obo
-stock springs - 20 obo
-3 stock struts, two back, only one front - 40 obo
-OEM VW BIKE RACK!!!! missing the locking mechanisms - 70 obo
-4 OEM center caps - 20 obo
-20 OEM lugs nuts - 10 obo
Electornics ------>
-Plantronics 640 Bluetooth 100 dollar value - 60 obo
[b]-CINEGO home theater digital projector - 400 (plays dvds and has built in speakers)[b] - picture can go from small like a tv to filling an entire wall! ONLY USED YOUR 2 MONTHS!
CINEGO!!
AEM CIA
TOE KIT FOR EG
Black door handle cover EG - 5 dollars
D series Flywheel
JL subs with box
GSR Timing covers (JDM and USDM)
Spoiler for the back glass
Turbo couplers
EK Gauge pod
B series thermostats
DC header - Bseries - 1 piece (MINT - NO DENTS!)
CRX si visors
CABLE b16 transmission outer casing
ls power steering pump OBD0
Blue Wheel
Passenger Manual window Crank
stock washer with motor
shift boot
crx fuse box cover
BOx for two ten inch speakers - 35 bucks - NO AMP!
Gas tank cover for EG
Frost White hatch door (bright light hides the dents!) - 20
CHEAP *** exhaust
front support for civic
Cheap cd player - 50 obo
BRIGHT RED VALVE COVER
I WANT TO BUY:
-GSR BLOCK- MUST BE IN GOOD CONDITION! - bare is better!
-silicone radiator hoses
-EG front lip
-black EG glove box
-STOCK EK floor mats (4dr front and back)
***Id much rather trade parts rather than have to buy all this stuff!!
Modified by nabin at 11:20 PM 2/16/2008
FOR SALE:
Turbo Stuff!! ------>-used 2 inch coupler - 3 with clamps
Aftermarket parts ----- >-Bseries stainless DC sports header - 175 obo
ECUs ------->-OBD2 - OBD1 wiring harness - 60 obo
OBD2 P72 - 65 obo
Audio
-MAP sensor - 5
D series stuff --->
More stuff----->
-EG wiper arms - 10
Exhausts---->
VW parts ----->
Electornics ------>
CINEGO!!
AEM CIA
TOE KIT FOR EG
D series Flywheel
JL subs with box
Turbo couplers
EK Gauge pod
CRX si visors
Blue Wheel
shift boot
crx fuse box cover
CHEAP *** exhaust
I WANT TO BUY:
-EG front lip
-black EG glove box
im not sure on the brand man. there is nothing written on it, but it looks brand new. i could take a little less seeing mine has a slim fan installed on it already.. let me know.
