Forgot to lube release bearing shaft........
I rebuilt my engine and put it back in my car. Then right before I am about to start it I realized that I forgot to lube the release bearing shaft.
Is there any way to lube this shaft without taking the whole car apart?
And how important is it to lube? Thanks
If you got most of the grease off when you wiped it, I'd pull the trans and grease it. Might be able to get creative with a grease gun with long flexible nossle, light, mirror, and a friend to work the clutch pedal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thepanda »</TD></TR><TR><TD CLASS="quote">Just spent the last 3 hours trying to get at the area you can't even see it let alone get some tools into it. How important is it that that area is lubed?</TD></TR></TABLE>
In those 3 hours you could've had the trans off, greased it, and put it all back together.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Furyof4 »</TD></TR><TR><TD CLASS="quote">
true
true
do you mean the nose the bearing rides on?
if so then yes you absolutely have to lube that. that nose is part of the tranny housing and the bearing will wear a groove in the aluminum.
remove your flywheel cover, u'll be able to get it in there.. i did, but besides that i feel sorry for you, i put my tranny on myself.. took me 3 hours to pick it up, hold it and move it so that the splindles lined up correctly, was a bitch in deed.. but a great learning experince.. glhf with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PPLH8R »</TD></TR><TR><TD CLASS="quote">Dont you hate when you forget to lube your shaft.</TD></TR></TABLE>
It's the worst, isn't it?
There is no pain like a chafed....
MySelfAffliction
Jun 26, 2019 06:59 PM
keithv
21
Mar 11, 2003 04:11 PM
