clutch help!!!!!!!!!!!!!!!
Old Dec 20, 2007 | 08:53 PM
93accordblue's Avatar
Default clutch help!!!!!!!!!!!!!!!
well i have a b16a with a hydraulic tranny and i just changed the clutch but the gears wont go inn, they go inn but you have to force them inn, what can be causing this and the old clutch did not look bad yet it was doing the samething please help me and be free to ask me questions
Old Dec 20, 2007 | 09:53 PM
H-EK22's Avatar
Default Re: clutch help!!!!!!!!!!!!!!! (93accordblue)
Did you do the install??? Checked your syncros, they might of busted up... have you tried a tranny flush
Old Dec 20, 2007 | 10:00 PM
Cln94EG1's Avatar
Miles on tranny cause u dont want to start flushing if its got lots of miles and how did this all start when did it start going into gear hard and what cause it
Old Dec 21, 2007 | 07:30 PM
Default Re: clutch help!!!!!!!!!!!!!!! (cln92eg)
WELL 1 DAY IT WAS WORKING FINE AND THE NEXT DAY THE GEARS JUST WOULDNT GO INN, SO I DECIDED 2 CHANGE THE CLUCH , AND YES I INSTALLED IT MYSELF
Old Dec 21, 2007 | 07:36 PM
z6hatchboy's Avatar
Clutch wont affect the "going in of gears, thats internal" unless you dont have enough clutch fluid or a bad clutch slave cylinder, clutch is just for putting the power down (holding and not slipping). If it grinds when you force it into gear its probly the syncros, if its just stubborn try checking/changing tranny fluid, or start building your arm muscle .
Old Dec 21, 2007 | 08:54 PM
H-EK22's Avatar
Default Re: (z6hatchboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy &raquo;</TD></TR><TR><TD CLASS="quote">Clutch wont affect the "going in of gears, thats internal" unless you dont have enough clutch fluid or a bad clutch slave cylinder, clutch is just for putting the power down (holding and not slipping). If it grinds when you force it into gear its probly the syncros, if its just stubborn try checking/changing tranny fluid, or start building your arm muscle .</TD></TR></TABLE>
Yeah pretty much self explanatory.... Hopefully you dont got a bad tranny
mrmoomoox
11
Apr 5, 2010 06:05 AM
Dc295kid
Dec 19, 2009 07:05 AM
nostreble
May 11, 2006 12:35 PM
tweak
Nov 16, 2003 06:16 PM
phatintegra
Mar 21, 2002 06:39 PM
