B16a Questions
Old Dec 20, 2007 | 08:24 PM
rustydusty1717's Avatar
Default B16a Questions
Hello all. i need some help from anyone that will help. basically i've got a budget of $3000-4000 Canadian and all i want to do is get my car running atleast 200 HP. Now i've though about turbokit but since everyone is running turbokits i've decided to go all motor. What would be the main things i should change to gain some serious HP? I've heard of flywheel, headers, intake, ecu...what else? keep in mind my budget is 3-4 grand canadian and my goal is 200+ hp.
Old Dec 20, 2007 | 08:37 PM
polything's Avatar
its possible however, i would recommend you to get a 200+ HP car...like a WRX
:D
-poly
Old Dec 20, 2007 | 08:47 PM
dirtyafrican's Avatar
1st thing to change? swap a 1.8 or 2.0 b series block w/ higher c/r and aggressive cams
Old Dec 20, 2007 | 09:42 PM
Default Re: B16a Questions (rustydusty1717)
alright so cams...what else? i was told earlier tonite that in order to get my b16a over 200 hp i'm gonna need about 10 grand? bullshit or is this guy telling the truth?
Old Dec 20, 2007 | 09:44 PM
95JDM's Avatar
yeah its going to be alot for that you should just get the turbo kit
Old Dec 20, 2007 | 10:04 PM
RiceKillinSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rustydusty1717 &raquo;</TD></TR><TR><TD CLASS="quote">alright so cams...what else? i was told earlier tonite that in order to get my b16a over 200 hp i'm gonna need about 10 grand? bullshit or is this guy telling the truth?</TD></TR></TABLE>
There is a good reason why most b16a owners opt for a turbo kit. You will spend 2-3X as much tring to get the same horsepower N/A. Good luck with your build though.
Old Dec 20, 2007 | 11:49 PM
sicky's Avatar
grammer nawzi
Default Re: B16a Questions (RiceKillinSI)
To make that power easy, just buy a B20 or LS bottom end and put your head on it. Problem solved.
Old Dec 20, 2007 | 11:53 PM
93egSLEEPER's Avatar
Default Re: B16a Questions (sicky)
BOOOOST FTW! making a b16 200+ whp NA is hard and expensive plus you run the risk of having emissions problems.
Old Dec 21, 2007 | 12:22 AM
sicky's Avatar
grammer nawzi
Default Re: B16a Questions (93egSLEEPER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egSLEEPER &raquo;</TD></TR><TR><TD CLASS="quote">plus you run the risk of having emissions problems. </TD></TR></TABLE>
He's in Canada, bud.
Old Dec 21, 2007 | 02:37 AM
krytoi's Avatar
if u got some cash i would get cams,intake mani, pistons, headers, cold air, nice ecu tune and dont forget spring and retainers =0
Old Dec 21, 2007 | 05:29 AM
crazyguy's Avatar
thats what i am doing now.but i am not sure if my engine set up will hit 200 hp mark. i have a stock jdm b16a sir 2 swap (170 hp already).i just bought some ITR cams..CTR high compression pistons (10.95 compression ratio with b16a head and block),wrist pins and piston rings..all new gaskets and o rings..new valve springs and retainer..aem fuel rail..and skunk2 intake manifold and TB..
i have already had dc sports header and after market cat back in the car right now.and i am planning to do the internal work soon..i will post pics later on and pm me if u have any more questions.
Old Dec 21, 2007 | 05:38 AM
EG_Warped's Avatar
that level of power is very attainable with cams and injectors and tune...
Old Dec 21, 2007 | 06:28 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: B16a Questions (EG_Warped)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG_Warped &raquo;</TD></TR><TR><TD CLASS="quote">that level of power is very attainable with cams and injectors and tune... </TD></TR></TABLE>
Hell no it's not.
Show me ONE B16A with cams, injectors, and tune making 200whp - hell show me one making 185whp.
Modified by B18C5-EH2 at 2:11 PM 12/21/2007
Old Dec 21, 2007 | 08:05 AM
thisisntjared's Avatar
Default Re: B16a Questions (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">
Hell no it's not.
Show me ONE B16a with cams, injectors, and tune making 200whp - hell show me one making 185whp.
&lt;---subscribes and waits.
i have come to the conclusion that unless you are going to pop the head, na mods for the 1.6 variants arent worth too much. there has been evidence that mods make a difference, just not enough bang for the buck.
Old Dec 21, 2007 | 09:13 AM
em1_sir's Avatar
what are you running this in..
sorry im from e town as well. just wondering if ive seen you around.
Old Dec 21, 2007 | 10:05 AM
kayelemenohpee's Avatar
Default Re: B16a Questions (em1_sir)
if your bore port polish? maybe and shove some big *** **** in there, but it probley go 1.7 or something, anyways is this true
who said that?
Old Dec 21, 2007 | 10:26 AM
Em1ForLyfe's Avatar
Lmao brah, your best bet is to just get a car that has 200+ hp stock, its gonna take a lot of cash out of your pocket to push any N/A B series motor over 200WHP... GL brah.
Old Dec 21, 2007 | 10:28 AM
Default Re: B16a Questions (Em1ForLyfe)
wait guys Remember its canadian money.
Old Dec 21, 2007 | 10:48 AM
Default Re: B16a Questions (kayelemenohpee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kayelemenohpee &raquo;</TD></TR><TR><TD CLASS="quote">wait guys Remember its canadian money.</TD></TR></TABLE>so tell us, what is the current conversion rate?
Old Dec 21, 2007 | 11:57 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: B16a Questions (thisisntjared)
Here's your answer:
If you want 200 CRANK horsepower then your best bet if find a 1.8L block, toss the B16A head on and find some nice ITR/CTR cams or Skunk 2 Stage 1/comparable cams with good i/h/e and tuning.
If you want 200WHP which is what the real world users here quote and discuss, good luck. It's not hard to do these days, but it will require a lot more money than you're looking to spend.
BTW:
I know nobody here will probably agree with me, but a good old Jackson Racing supercharger sounds like an alternative here. Others will bash it, but honestly it's about as trouble free and easy to install and use. It's reliable, would get you closer to the 200whp mark than anything N/A for the same price, etc.
Just saying...
Old Dec 21, 2007 | 12:04 PM
andoxviii's Avatar
Don't bother trying to achieve that goal with a b16a. Such a waste of money. You can spend a fraction of the cost and piece together a nice turbo kit and go over 200 anyways.
There is nothing wrong with remaining naturally aspirated, but for God sake, not with a 1.6L
Good luck
Old Dec 21, 2007 | 02:44 PM
thanks for all the help guys...i guess going all motor isn't going to cut it. as for the supercharger i heard of a b16 engine you're better off going with a turbokit but if a supercharger kit is gonna be cheaper and get me over 200 whp that's all that matters
Old Dec 21, 2007 | 03:07 PM
92_civic's Avatar
Default Re: (rustydusty1717)
**puts on flame suit**
I'm sure this is going to **** some people off, but I managed to get 176 WHP (yes wheel) out of a 100% internally stock b16a2 (stock injectors too) with nothing more than a used chikara LS header (50$) test pipe, cat back exhaust (made the test pipe and catback myself) a VAFC (again used 65$) walboro fuel pump (125$) skunk cam gears and a snow's performance (www.snowperformance.net) water/methanol injection system (299.99$)
I think the dyno vid is still up on my website (in my sig) all dyno tuning was done at my shop, and since this is one of my employees cars dyno time was free for him...good thing too...took over 9 hours to get the tune perfect...dyno is a land and sea chassis dyno
that was less than 1k$ worth of parts to get that point...I'm sure that with some more bolt ons (cams, and a decent header) I could have picked up another 10-15 WHP gets you pretty close to 200 WHP for 2k$ US in parts...it's the dyno time to tune it that kills ya
but seriously, throw a 500$ nitrous kit on it with a 50-75 shot, and your right there too...lots of different options to get 200 WHP out of a b16 for that kind of money...most of them do involve forced induction though
Old Dec 21, 2007 | 05:18 PM
what about this supercharger kit? i don't want to have to buy anything so if someone could let me know if this kit is good and if it includes EVERYTHING and if not what else would i have to get?
http://www.supercharger.com/Sh...33371
Old Dec 21, 2007 | 08:10 PM
92_civic's Avatar
as long as your going to keep the boost low (stock boost setting is 6psi I believe) and set your timing to their instructions you should be in pretty good shape with that kit, I would still recommend a walboro pump and a good header
